Question about HP Computers & Internet
Our house burned and we saved our computer all the cables on the back were removed now i can't remember how to connect them
  • 33 Answers
Most cables on motherboards are different sizes, so the entire puzzle is just matching the right cable to the right connector. If you are plugging in "IDE" cables, they are flat 50pin ribbon cables, just use the primary one first for your main hard drive.
Posted on Mar 15, 2011
How to change the thermostat house in a Dodge 2004 intrepid
Check this procedure for...
2.7L Engine
  1. Disconnect negative cable.
    CAUTION Do not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
  2. Drain cooling system.
  3. Remove radiator lower hose from thermostat housing.
  4. Remove nuts from heater tube flange studs.
  5. Loosen starter bolt at heater tube bracket.
  6. Pull heater tube out of thermostat housing and position out of the way.
  7. Remove bolt and two studs.
  8. Remove thermostat housing, O-ring and thermostat.
  9. Remove thermostat housing bolts.
To install:
  1. Clean gasket sealing surfaces.
    NOTE Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
  2. Install thermostat and seal into thermostat housing .
  3. If removed, install two studs.
  4. Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
  5. Lubricate new heater return tube O-ring with coolant.
  6. Position heater return tube flange over two studs. Install nuts.
  7. Tighten retaining nuts to 53 inch lbs.(6 Nm).
  8. Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
  9. Connect the lower radiator hose to the thermostat housing. Install hose clamps.
  10. Refill cooling system.
  11. Inspect for leaks.
  12. Connect negative cable.
3.2L & 3.5L Engines
  3. Raise vehicle on hoist.
  4. Disconnect electrical connectors from engine oil and power steering pressure switches.
  5. Disconnect radiator and heater hoses from thermostat housing.
  6. Remove thermostat housing bolts.
  7. Remove housing, thermostat, and gasket.
    NOTE The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing using a suitable hand held grinder. It is not necessary to restake the replacement thermostat into the thermostat housing.
To install:
  1. Position gasket on thermostat and housing.
  2. Install thermostat housing, gasket and mounting bolts onto block. Tighten attaching bolts to 105 inch lbs. (12 Nm).
  3. Install radiator hose.
  4. Install bypass hose.
  5. Connect electrical connectors from engine oil and power steering pressure switches.
  6. Connect negative cable.
  7. Fill cooling system.
  8. Inspect for leaks.
  9. Lower vehicle on hoist.
Hope helps (remember to rate and comment thius answer).
Apr 28, 2011 | 2004 Dodge Intrepid
Tip
How to transport your computer from one place to another
<p><span>Most of the people usually save the original containers for items like home electronics and computers, and if you also these containers then it nice method of transporting the equipment. If you have not save it, most moving companies make containers especially for packing, and you can buy containers for packing and protection. And you should have some non-static packing material such as traditional bubble wrap, peanuts and other packing supplies tend to create static.</span><br /> <p><span>These are some useful tips for especial items or things. </span><br /> <p><b><span>Securing your Data- </span></b><span>this is very important to backup all existing data, either by burning it to CDs or DVDs or in other drives. Most of computers provide their users with a set method for backing up all of the data files. This important because using this method you ensure against permanent loss during the move.</span><br /> <p><b><span>Before packing disconnect all cables</span></b><span> - you should remove all cables from main part of the computer. But be care when removing cables, you should remember the cable port and labeled it. After appropriately labeling the cables it is a good idea to store them together in a large plastic bag.</span><br /> <p><b><span>You should empty the equipment</span></b><span> - before packing you ensure that all <span>computer</span> drives should be empty. And all ports should have media cards or other items removed before packing. Printer or other items that use toner and ink cartridges must be removed before packing and preparing for transport. </span><br /> <p><b><span>Final loading of computer</span></b><span> - for finally moving the computer you can hire any moving companies to transport the computer. And you should prefer transport computer in a car rather than in van.</span><br /> <p><span>By using these tips you can move your computer safe.</span><br />
on Dec 24, 2010 | Computers & Internet
How to replace a thermostat
2.0L Engine
SOHC ENGINE
(see Figure 17)
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner outlet tube.
CAUTION Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Drain the cooling system until the level is below the thermostat.
  2. Unplug the coolant temperature sender and coolant temperature sensor electrical connections.
  3. Disconnect the upper radiator hose and heater coolant hose from the thermostat housing.
  4. Unfasten the thermostat housing bolts.
  5. Remove the thermostat housing and the thermostat.
  6. Clean the gasket surfaces thoroughly until all traces of the old gasket residue are removed.
Make sure the tabs on the thermostat engage properly into the slots in the housing.
Fig. 17: Remove the thermostat housing mounting bolts-2.0L SOHC engine
To install:
  1. Install the thermostat in the housing making sure the tabs engage.
  2. Install any new gasket required.
  3. Install the thermostat, housing and bolts. Tighten the bolts to 8-12 ft lbs. (10-16 Nm).
  4. Connect the upper radiator hose and heater coolant hose to the thermostat housing.
  5. Attach the coolant temperature sender and coolant temperature sensor electrical connections.
  6. Fill the cooling system.
  7. Install the air cleaner outlet tube.
  8. Connect the negative battery cable.
  9. Start the car and check for leaks.
DOHC ENGINE
(see Figures 18 and 19)
  2. Unplug the Camshaft Position (CMP) sensor electrical connection.
  3. Unfasten the water hose connection retaining bolts and move the connection aside.
  4. Remove the thermostat and seal from the housing.
Fig. 18: Location of the water hose connection mounting bolts-2.0L DOHC engine
Fig. 19: Remove the thermostat and seal. Inspect the seal for damage and replace as necessary-2.0L DOHC engine
To install:
  1. Inspect the seal and replace it if damaged.
  2. Install the thermostat and seal in the housing.
  3. Install the water hose connection and bolts. Tighten the bolts to 71-97 inch lbs. (8-11 Nm).
  4. Attach the Camshaft Position (CMP) sensor electrical connection.
  5. Fill the cooling system.
  6. Start the car and check for leaks.
Hope helps (remember to rate this answer).
Dec 21, 2010 | 1999 Ford Escort
This is for the 2.7L:
2.7L Engine
    CAUTION
To install:
    NOTE
This is for the 3.2L and the 3.5L:
3.2L & 3.5L Engines
    CAUTION
    NOTE
To install:
Nov 01, 2010 | 2002 Dodge Intrepid
How do I change the thermostat on a 1999 dodge intrepid 2.7L
The thermostat on the 2.7L and 3.5L engines are located on the lower left side of engine, near the front. The thermostat on both engines are on the inlet side of the water pump.
2.7L Engine
To install:
Hope helps (remember to rate and comment this).
Sep 29, 2010 | 1999 Dodge Intrepid
Remove thermostat
300M, Concorde, Intrepid, LHS, 1998-2004
THERMOSTAT - Removal & Installation
2.7L Engine
To install:
3.2L & 3.5L Engines
To install:
Hope this help (remember comment and rated this).
Apr 04, 2010 | 2000 Chrysler Concorde
How to replace thermostat
300M, Concorde, Intrepid, LHS, 1998-2004 - Thermostat Removal & Installation 2.7L Engine
To install:
3.2L & 3.5L Engines
To install:
Hope helps with this (remember rated this) Good luck.
Feb 02, 2010 | 2001 Chrysler 300M
Computer keeps rebooting on its own
Most likely a virus has or malware has got into the system try SAFEMODE and install or do virus check if this does not work get someone to download one of the well known free virus checks and when you use as boot CD it will do virus check other options are more drastic like take hard drive out and do virus check with another computer of Format but try and save date before these options are attempted
Jan 10, 2009 | Computers & Internet
My dvd-rw can't read dvd but can read cd
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
May 18, 2008 | Computers & Internet
HP DVD1040e XH12
•HKEY_LOCAL_MACHINE
•SYSTEM
•Control
•Class
and then restart the comptuer
even if this thing doesnt work replace the drive!!!
May 15, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
