Question about Kinyo Audio Zone 2.0 Sound System Computer Speakers
I purchased new Audio Zone 2.0, Kinyo speakers. They are plugged into the audio port, turned on (green light is lit), the sound on the speakers and computer screen is not muted, but I still cannot get sound. I uninstalled, restarted and updated the driver, but am still having problems.
  • 55 Answers
Try the speakers with some other audio device like iPod or any other computer, if got sound then the problem is the computer, try to download the audio driver again and reinstall it restart the PC and test the audio again.
Posted on Mar 15, 2011
    Master:
  • 388 Answers
If its running on xp go to contol panel you will see a logo of a spearpker open it go to audio make sure the correct sound output is selected
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
No sound using windows vista 7
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 04, 2010 | Kinyo Audio Zone 2.0 Sound System Computer...
They don't work - no sound - do I need to download a driver?
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 16, 2010 | Kinyo Audio Zone 2.0 Sound System Computer...
No sound threw speakers
check the windows settings if they are not on mute check the drivers check the cable connection if they are connected on correct port
Oct 17, 2010 | Kinyo Audio Zone 2.0 Sound System Computer...
I want driver supporting it
this is a plug and play device, it does not need drivers
if they are not working make sure your computer sound card has its driver loaded and the speakers are connected to the green audio jack in your computer
Aug 13, 2010 | Kinyo UC270B 2 Speakers
No sound from new kinyo audio zone 2.0 speakers
possibly, try to type kinyo drivers in google. see if they have drivers
Jun 20, 2010 | Audio Players & Recorders
Speaker will not work. Cannot adjust the volume.
Make sure you can see the small LED light on the speakers. If I remember correctly, those speakers are USB powered, and need to be plugged into the USB port for power, and the green audio output port for sound signal. If they are plugged in, and you cannot turn them on, you have broken speakers. If you CAN turn them on, then ensure that the audio cable is plugged into the green audio output jack (sometimes it has a headphone icon by it) and make sure your computer has not muted the audio.
May 17, 2010 | Dell A225 2 Speakers
How do i hook up the speaker to my computer
if you have stereo speakers, connect it to the green audio port on your computer. if you have digital surround, you have green, yellow and black. insert the speaker connectors accordingly.
Mar 14, 2010 | Acer Aspire T310 PC Desktop
Connecting the system
HI there bud..what you will need to do , is go to a PC or electronic store . Ask them for a Audio jack to RCA cable for your 5.1 Channel PC speakers , once bought , COnnect the required speakers , and .done :)
Hope it works.Happy new year ;)
Jan 03, 2010 | Kinyo GZ-501 5.1 Game Zone Surround Sound...
No sound from speakers
Try reinstalling the soundcard drivers. If you can tell me the soundcard make, I can find them for you
Apr 11, 2009 | Computers & Internet
Kinyo Audio Zone 2.0 Sound System Computer Speakers Logo
95 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
