Question about Gunvault Multi Vault GV2000 Std
Need to reset finger code got key how do i do it GUNVAULT MULTI GV2000
Tip
How to enable 2 Finger Scrolling, like MAC ie, multi touch in Windows
Multi-touch or multitouch functionality has been attracting consumer attraction, thanks to iPhone and iPod Touch, two-finger-scroll in Apple MacBook with TrackPad, and Windows 7, which has built-in multi-touch mapping application, photo viewing program, and gesture support in Internet Explorer 8. Multi-touch is essentially a set of interaction techniques which allow computerusers to interact and control graphical applications with fingers.
However, for marketing reason, Synaptics official standard drivers for most Synaptics TouchPads does not support multi-touch Synaptics Gestures. Synaptics' drivers lock gesture features on all non-supported OEM notebooks and laptop PCs, except for certain gadgets such as ASUS EEE PC. So multi-touch is disabled even though touchpad hardware does support them.
But now if you want to experiance this awesome multi touch features, well there is good news. One guy has developed a modded driver for synaptic which will enable the multi touch functionality in a normal PC with windows.
The Synaptics TouchPad driver should support all Windows operating system such as Windows XP, Windows Vista and Windows 7. However, do note that the digital signatures of the modded drivers have been broken, and the drivers are no longer signed. Thus, there may be issue when use in 64bit operating system which enforces strict driver signing requirements.
Installation:
  1. Uninstall all current Synaptics drivers from Control Panel's Add and Remove Programs or Programs and Features.
  2. Restart the computer.
  3. Install the modded driver by running the setup.exe inside the ZIP archive.
  4. Windows should prompt a warning about unsigned driver. Continue to install the driver anyway.
  5. Restart the computer after installation is completed and Synaptics TouchPad driver is updated.
  6. In Device Manager's Mouse and Other Pointing Devices" section, Synaptics PS/2 Port Touchpad should have driver version of 10.2.4.
Now just play around a little bit and you will know how awesome this features are. icon_smile.gif
Also there is a two finger scrolling application which is a project hosted in google code. So this application is all you need if you just need the 2 finger scrolling functionality in windows.
This application can be found here:
Download: http://code.google.com/p/two-finger-scroll/downloads/list
The moded drivers from synaptic can be found here:
Download synaptics_v10.2.4.0_allOS_modded_b2.zip or touchpad_synaptics_v10.2.4_vistax32x64_xpx32x64_modded_build2.zip
Or you can just download all the required files from here:
Mirrors:
  1. Synaptics Multi touch mode (all) - Selfhosted
  2. Synaptics Multi touch mode (all) - Rapidshare - Recommended
IMPORTANT: Do not upgrade the Synaptics TouchPad driver if you love these touch features, as Sypnatics locks and disable the advanced touch features from driver v11.0.0.0 onwards.
on Oct 06, 2010 | Microsoft Windows Vista Ultimate Edition
Does anyone have keys for Gunvault gv2000? Lost my keys during a move. Did not use the electronic key pad. Any ideals?
That is like asking if we have the keys to your house or car. They come keyed different, however if you are lucky there is a code on the lock it self. Best solution take it to a locksmith shop. Look for one that had been around for at least 10 years and preferably works on safes. This lock can be picked open and keys fit though not easily. The easy way is to drill it out and replace the lock. Unfortunately the cost of this is going to be close to a new container so I hope it has a code on the lock 20-30 bucks on the high end for a code key. Take it in to a lock shop.
good luck.
Sep 14, 2011 | Gunvault Multivault Deluxe Safe Storage...
I have forgot my lock code and i cant switch it
All you need to do is to reset the phone. Below are the information you need to reset the phone.
Try the *#7370# reset code and if that does not work try the deep reset.
Always remember to backup your phone before performing resets as your data may be lost.
Then try the "3 finger deep reset". With the phone powered off, depress and hold these three keys simultaneously "*" "3" "green phone" and then power on phone using the on/off button whilst keeping the three keys depressed until you hear start-up tone.
Hope this was helpful?
Apr 12, 2011 | Nokia E5 Cell Phone
Konica minolta DI 750 error code SC36-06
Hi this error code is an issue with the fuser unit it could be the thermistors lamps ect you will need to check the parts and replace worn or end of life parts if you hold down the utility key and power off the machine then power back on the machine holding the utility key wait about 39 seconds then take your finger of the utility key on the screen trouble reset will appear press the screen power off the machine then back on again this will reset the code
Feb 09, 2011 | Office Equipment & Supplies
How do I reset code on multi vault gv 2000
I went here for your manual:
Do you have the key?
Looks like you can remove power for 30+ seconds and reset to the factory defaults (there's external power and AA batteries inside.)
The PDF file linked above has the "learn" precedure for setting the code. And there's a FAQ list on page 13 that you might find helpful.
:o)
Jan 04, 2011 | Gunvault Multi Vault GV2000 Std
How do I reset code on my gun vault GV2000
Enter the 1,2,3,4 factory number.
When the door opens, immediately press all 4 keys are once and release.
A red light will come on. then enter new code. lamp will turn off.
to confirm the new code enter it a second time.
red light blinks, an error has occurred or your timing was off, so just start over with the factory 1,2,3,4 code.
Nov 28, 2010 | Gunvault Multi Vault GV2000 Std
Code setting instructions for GunVault
Hi, I found something on amazon, take a look: Amazon com gun vault manual Have a nice day
Mar 11, 2009 | Gunvault Multi Vault GV2000 Std
NO LEARN BUTTON ON GUN VAULT 1000
Here are the Instructions I have to my older (Sept 1998) GV2000-A:
PROGRAM YOUR SECRET CODE:
This will cause the red lamp to come on, so programming can begin.
Note: Avoid doing this in bright light.
Enter your new secret code. The lamp will go out.
Now immediately confirm your new Secret Code by entering it a second time.
If the red light blinks, an error has occurred or your timing was off, so just start over with the factory 1,2,3,4 code.
Jan 25, 2009 | Gunvault Multi Vault GV2000 Std
Gunvault Multi Vault GV2000 Std Logo
140 people viewed this question
Top Gunvault Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Gunvault Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
