Question about Brother XL-5130 Mechanical Sewing Machine
Unable to lengthen stitch size on brother XL 4050 sewing machine
bargainbox
  • 1388 Answers
SOURCE: stitching looping
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....the question you pose could have 2 meanings....this reply is for looping thread.
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cc3f045.jpg...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes. ie a different colour top and bottom just for the test.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case....no case ? then make some sort of cover ! Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you need any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 23, 2008
bargainbox
  • 1388 Answers
SOURCE: tension
As this happened mid project, I would pay most attention to check the top tension for lint or thread...........this full process of elimination ought to cover all possibilities.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
TOP THREAD TENSION:
projects).
BOBBIN TENSION:
TOP LOADER:
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
back properly.
165ca5c.jpg FINISHING UP
OTHER ISSUES:
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jun 24, 2008
  • 323 Answers
SOURCE: unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Posted on Jul 18, 2008
  • 240 Answers
SOURCE: sewing machine Brother xl-5301
When the bottom stitches are loopy it is the top tension which is wrong. I suspect that it is not threaded correctly for it to be this bad. If you have a tension dial make sure that the thread is properly between the disk. Try the top tension on 4-that is an "average" normal setting. Gradually turn it up as needed. A good way to test tension is to use 2 contrasting colours-red and white are good. You will see at a glance where the problem lies and how well you are correcting it with adjustments. You should barely see a trace of the top colour coming through. Rethread the machine top and bottom with 2 colours-set dial to no 4 and go from there.
Posted on Jun 13, 2009
fixit2k9
  • 55 Answers
SOURCE: instruction manual for a Brother XL-3750
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_xl3750eus.html?reg=us&c=us_ot&lang=en&prod=hf_xl3750eus
from here u can download manual...
Posted on Jun 21, 2009
I couldn't find the Brother XL-3520, so I'll just ask here. I noticed that I have a single needle (already attached to machine) and a double needle attachment but I need a thicker needle for...
most domestic sewing machines use 130/705h system needles - buy a pack each of size 70, 80, 90 and 100 to start. if you plan on sewing knits (stretchy) fabrics then buy a couple packs of ball points in size 70 and 80. put in a new needle for each garment you sew as a needle goes blunt in about 6 hours depending on what you are stitching. visit www.sewing.about.com and check out sewing machines 101 and debbie's article on sm needles for more good info. depending on what your heavier weight fabric is you may need to use a 110 size to handle it. the denser the fabric the bigger it needs to be.
May 17, 2011 | Brother XL-3510 Mechanical Sewing Machine
Brother xl 5700 - stitch selection?
Try Googling (brother)(XL 5700)(manual) without parens.
Oct 26, 2017 | Brother XL-5700 Mechanical Sewing Machine
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
Lengthening stitches.
You can adjust the length of the Zigzag (Satin)
Stitch using the buttonhole fine-adjusting screw. You will find it right above your stitch selection dial.
> For a longer stitch length, turn the
buttonhole fine-adjusting screw with a large
screwdriver in the + direction.
> For a shorter stitch length, turn the
screwdriver in the - direction.
Hope this helps
Apr 06, 2009 | Brother XL-2230 Mechanical Sewing Machine
Sewing hems on pants without stitch showing
you want to use a blind stitch. Refer to your manual and it should give you details on how to set the machine for that stitch.
Apr 05, 2009 | Brother XL-3510 Mechanical Sewing Machine
Machine not sewing
Have you checked that the tiny screw in the bobbin is not loose, sometimes this creates this problem for me or if the bobbin size is incorrect.
Dec 13, 2008 | Brother XL-5340 Mechanical Sewing Machine
Problem while sewing buttonhole with a thick thread
You will need to use a size 18 needle or even better a size 18 top stitch needle. It has a larger eye.Tighten the tension to about an 8 and try it. You may have to lengthen the stitch length to make it sew satisfactorily.. If it won't work on 8 go to 9 and if it still won't work, wrap the thread around the bobbin winder guide (on the left top of the machine) for more tension. It is very hard to sew heavy duty thread on a household machine.
sewman7
Jul 06, 2008 | Brother LS-2125 Mechanical Sewing Machine
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
117 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
