Question about Artec 16X DVD-ROM 48X CD-ROM Drive with Power DVD Software DVD Drive
Hi Somehow i deleted the Power DVD software for my Artec 16x DVD CDRom drive Hardware that came preinstalled. How can i get the software back
    Master:
  • 388 Answers
You will need the code for power dvd google it and download it or do a system restore
Posted on Mar 15, 2011
ARTEC DHM-G48R 5.xx (16x/48x) IDE DVD-ROM 16X is not showing up as DVD Drive it is showing up as CD Drive. What do I do to fix this???
If you insert a DVD disk, and then open "My Computer", does it now correctly show that a DVD disk has been detected?
Jun 26, 2011 | Artec DHM G48 DVDROM drive internal 16x...
Artec wsm-52x Problem...My CDROM drive keeps opening and closing. I tried disabling it in Device Mgr, but the problem still exists. I also uninstalled it in Device Mgr, but still it keeps opening and...
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 11, 2011 | Artec WSM-52X-UR CD-RW Burner
My CDROM drive keeps opening and closing randomly. I have tried disabling it in Device Mgr, but it still is opening and closing. I also uninstalled it in Device Mgr, but still it won't stop opening and...
Do you actually use the CDROM drive?
I assume no because you say you keep trying to disable/uninstall it- If this is the case, just unplug the power cord from the back of the drive.
Only thing I can think of that would cause this is a faulty/intermittent connection inside the CD Drive, which could only feasibly be fixed by replacing it. They're like $12 these days.
Dvd rom drive does not work
Try to open control panel then click add hardware. If you have entered the dialogue box, answer whatever is asked according to what you're searching. Then click whatever hardware your PC would like to detect then click finshed. After the detection, close the wizard box then try to open your DVD ROM and try it.
Hope this answers your question.
Feb 18, 2010 | Artec 16X DVD-ROM 48X CD-ROM Drive with...
Drive door opens and closes
Ive heard of joke programs which cause this but after restarting the computer it stops. If you are confident enough to remove the side cover off PC with power UNPLUGGED. Try disconnecting the data cable from CD drive. Now with hands away from case plug power back in and start up PC see if it still does it? If it still does it throw the CD drive away if not its a software problem..........get back to me on more ideas on what to do next.....please include your version of windows and if you remember what you were doing on pc when this started?......cheers from Scott
Nov 01, 2009 | Artec (WSM52XSR) CD-RW Burner
16x dvd-R dISCS
Can you read from the CD-RW drive? If you can then the optics are most likely fine. Try reading from the disk you are trying to write to. It should show a lot of space available if you check it's properties. If not, then that disk has likely been closed and you can't write to it any more. If you can't see the drive on your computers HARDWARE viewer, then the drive either isn't connected (you have said it is), or power isn't getting to it. If you can read from a factory produced CDrom, then you should be good to go.
Jan 27, 2018 | IBM Electronics - Others
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Code 39 for dvd drive
You can solve this problem by going to start, then run, type regedit. open hkey_local_machine, then system, then control, then class, then 4D36E965-E325-11CE-BFC1-08002BE10318, once in this go over to the right hand side and delete upper filters and then lower filters. restart your computer and your dvd/cd-rom drive will work properly, if you look in device manager there will no longer be a question mark and it will tell you all is working correctly.
Jan 06, 2008 | LG Electronics 16x DVD and 48x CD-ROM...
Lost recording software kit
If you lost the software, you can try contacting LiteOn for a replacement, but you'll probably have to go to your local tech store and buy more software. I recommend Nero or Easy CD/DVD Creator, or get the opinion of someone that works there. Make sure you do NOT open it until you get home and check online that it has the features you need, as you will be unable to return it if you open it.
Nov 08, 2007 | Lite On LITEON 16X DVD BLACK OEM (Come...
My DVD-ROM cant read Video Files
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for DVD/CDROM Drives, click it and your DVD drive will appear. Right click on it and delete. Restart PC and windows will find your DVD drive again and install it. Try a dvd again and see if it is working, if not it's time to buy a new one i'm afraid, but they are very cheap to replace.
Mar 08, 2007 | Lite On LITEON DVD-ROM16X, 21600KB/sec...
Artec 16X DVD-ROM 48X CD-ROM Drive with Power DVD Software DVD Drive Logo
50 people viewed this question
Top Artec Computers & Internet Experts
David Payne
David Payne
Are you an Artec Computer and Internet Expert? Answer questions, earn points and help others
