Question about LG FLATRON L1919S-SF 19 inch LCD Monitor
HOW TO CHECK A LG FLATRON L194WT-SF MONITOR FUSE, THE REAL PROBLEM IS HOW TO REMOVE THE BACK COVER
  • 11,361 Answers
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194W&kategoria=monitor&kat2=all
After removing all the screws and the base, I use thin flat blade screw driver to crack open the case starting at the bottom egde and work your way around, just watch out for any cables attached to the front bezel. The monitor is not made to be easily open up.
Please read my guide so you will know what to look for inside the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 16, 2011
  • 1,684 Answers
Here is a repair guide for the L196WTQ model that is basically the same unit as the L194WT. The repair guide has pictures and video instruction showing how to open the unit and what to look for on the power supply board. I hope this helps.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
Posted on Jul 13, 2012
How to opan lg crt monitor back case
LG Flatron Ez T710BH 17" CRT Monitor
TILT/SWIVEL & BACK COVER REMOVAL
1) Set the monitor face downward.2) Carefully remove the Tilt/Swivel by pulling it upward.3) Pressing the latch (b), Back cover by pushing it upward.4) Release the latch (c). (See Tip Spec.)5) Slide the Back Cover away from the Front Cabinet of the monitor.
Oct 28, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
I just got my LG L194WT-SF with an older computer and dont know what hapin, but it dont turn on i have try'd difrent power cords but still no power ive seen outher people with same problem but no awsners..
Hi There,
It's used LCD Monitor, right? You can read my Tips about this kind of issue, just click here.
Let me know if there is not clear enough.
regards,
dm
Dec 16, 2010 | LG L194WT 19" LCD Monitor
LG Flatron L194WT Monitor no power
It can be as simple $5 worth of caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
http://www.badcaps.net
May 27, 2010 | LG Flatron L1750S 17" LCD Monitor
LG FLATRON L1953T-SF 17" LCD Monitor Has no power? I checked the fuse, it's OK, tried different cords still no go? would it be the power supply itself?
Did you inspect the caps, any bulging one? Measure the power supply to see if you do have 5v and 12v on the power supply/inverter board.
See pictures and websites so you will know what to look for:
Apr 15, 2010 | LG Flatron L1715S 17" LCD Monitor
L194Wt doesn't turn on when connected to power, no power light-nothing. This monitor connects directly, no transformer in the power cord.
You need to open it up and inspect the AC main fuse, capacitors (with bulging top/seal), burtn parts, etc. see example of failed monitors due to bad caps, lamps, transformers, etc: http://s807.photobucket.com/home/budm/allalbums
Post back as to what you see inside so we can guide you further.
Mar 20, 2010 | LG 22" FLATRON LCD Monitor
Hi My LG Flatron MDL L194WT-SF just stopped working. no power surge or power outages. Can this be repaired or is there an internal fuse that may have blown. it is just like new and hate that it failed....
They have an internal power adaptor which does contain a fuse. However the fuse is soldered to the board so you need soldering skills to change it. Also, if the internal fuse has gone then it's probably because another component such as the transformer has gone in which case it won't help.
Unless you know how to troubleshoot electronic boards a component level you're almost certainly out of luck here I'm afraid.
Jan 14, 2010 | LG Computers & Internet
My screen keeps going blank after about 2 hours
check the flexible connectors conecciom tambein There is a false contact
Aug 21, 2009 | LG Flatron L1710S 17" LCD Monitor
I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
Apr 16, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG FLATRON L1919S-SF  19 inch LCD Monitor Logo
3,838 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
