Question about Espressione Caf? Dolce Aroma
After descaling, it still says descale how do I reset it?
After descaling it, still says descale how do I reset it?
Thanks.
Reynriley@gmail.com
  • metalstorm Dec 08, 2008
    I have the exact same problem.
Looking for one of these for parts 239-292-2219 if anyone has or knows where I can find one
Posted on May 22, 2012
    Problem Solver:
  • 5 Answers
When it gets to descale,
it says add solution.I could not find where to get any so.I added about 1/2 cup vinegar to the water tank and filled it up. Make sure to put a big bowl under the spout to collect all the water It has to go through descale cycle 4 times, (don't let the water run out) then it will say pour in pure water, so empty the water/vinegar and add water only, then it has to run through this cycle 4 times. It takes approx 30 min or more to do this, then it will say READY.
Posted on Jan 11, 2011
Please contact the service center and speak to Steve at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700 Steve
info@electra-craft.com
www.electra-craft.com
Posted on Aug 20, 2008
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
If descale not function, how can I do?
Try reading the user manual. You can find it at: http://www.cerinicoffee.com/saeco-user-manuals-28/ or there is a video on how to do it at: https://www.youtube.com/watch?v=k6iGAQ5C8hs
May 05, 2015 | Saeco Royal Digital Espresso & Coffee...
Descale prompt stays on after descaling?
in the menu just after descal go to signal descal then press enter and reset the counter.
May 01, 2013 | Saeco Magic Comfort Plus Espresso Machine
Hello , I got a present of a Saeco Royal Professional without an instruction booklet . The machine tells me it needs a descale . Can you please advise as to how . Many thanks , Sean Kavanagh
Hi
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the steam knob then open it again to rinse your machine. When its done exit the descale mode and go to the "Reset descale" just under it and enter. Choose "Yes" and push the enter button to accept. It will tell you when it needs to be descaled again.
If you want to make your machine last a long time, go to the water hardness in the menu and change your water hardness to the #4 and always push the enter button if you want to make your changes permanent. If you don't, no changes will be made and it will still be the same when you exit.
Jan 06, 2011 | Saeco Royal Professional Espresso Machine
Keep getting "decalcify" message
Go to MENU and scroll down and find SIGNAL DESCALING. Select ENTER the machine will ask RESET , YES or NO. Select YES and ENTER.
Jul 12, 2010 | Saeco Royal Cappuccino Espresso Machine
Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Jul 14, 2008 | Saeco Magic De Luxe Espresso Machine
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
The button all the way on the left is lit up in red!
the machine still work fine still descaling time with descaler not vinegar .vinegar no good descaler melt calcium follow what mark on the product to descale to reset the light i think you have to hold the steam button for 10 second thanks for using fixya pierre p.s im gonna double check how to reset the light ill get back to you
Feb 22, 2008 | Saeco Magic De Luxe Espresso Machine
2 messages: descale, and ventilate plus no hot water only steam
descale you need to use special descaler not vinegar vinegar is not strong enought and remove calcium in little piece that might block elsewhere descaler melt calcium 1 part water 1 part descaler fill the water container start machine open side valve for few second turn it off wait 15 minute repeat untill empty after rince very good that stuff is corosif go in thr menue reset the descaler mode and voila !
THANKS FOR USING FIXYA
FROM MONTREAL
CANADA PIERRE
Feb 18, 2008 | Saeco Royal Professional Espresso Machine
Trouble Lights Stay On
How long does it take for your machine to grind for 1 cup? Longer then 10 seconds? Grinder setting?
Descaling should be done every 2-3 regardless if the light comes on or not. To reset the light hold the steam button until the light goes off.
Descaling information can be found at http://www.cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Hope this helps!
Oct 09, 2007 | Saeco Magic De Luxe Espresso Machine
Espressione Caf? Dolce Aroma Logo
343 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Douglas Dinnebeil
Douglas Dinnebeil
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
