Question about Weather King Heating & Cooling
MFD/FAB 05/2007 model # 13AJA42A01 serial # 7280N210704257 Unit wont come on no humming or anything
2 Suggested Answers
  • 1033 Answers
SOURCE: A/C suddenly started blowing hot
Hello, sounds like a bad fan capacitor. Check out the capacitor does it look swollen or bulged?
Posted on May 31, 2011
How can I find comfotmaker maybe 1987 cannot find serial # NEED CAPACITOR MFD & VOLTS
If you need new capacitor you have to buy capacitor MFD and VOLTS same old capacitor.no need serian and anything.
Jul 15, 2014 | Heating & Cooling
Need to know capacitor size for a upla036jaz compressor, unable to read
need to know model and serial # of unit to look up values in mfd.
May 02, 2014 | Ruud Heating & Cooling
Dvd fab 8.2.1.0 serial number
Fixya will not give out any serial numbers, Activation Codes,
or Key Codes. It is illegal to pirate software
Oct 11, 2012 | Computers & Internet
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
Carrier 38ckc036 fan will not run all you get is a loud humming sound. You can sometimes get the fan to run if you assist it with a stick but then it stops running after a few minutes
The motor may be burned up on your fan. However, it may be just the capacitor. To check this you will need an ohm meter with a mfd setting. Disconnect the power from the unit. (if it is installed correctly there should be a disconnect near the unit). Also shut of the furnace. This is to prevent you from doing damage to the 25V circuit. Remove the wires from the c and fan terminal on the capacitor. The capacitor is a round cylinder with three groups of terminals on the top. (if it is still original) set your meter to MFD and put one probe on the C terminal and the other on the fan. The meter will read OL for several seconds and then give you a number. Check the number on the meter against the lowest number written on the capacitor (I think this model uses a 35/5 370) If the MFD is not close to the posted number you probably just need a capacitor. If the top of the capacitor is poofed out (dome shaped) It is probably a safe bet it needs replaced. Hope this helps.
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
Looking for an MFD for a carrier with serial # G753756 If I'm correct, this unit is from june of 1975. Is this correct?
If you are talking about a Capacitor (Round or Oval) it wont matter what make or year the unit is,.,,.,.simply match the MFD rating on the old capacitor with the new one....ie:5MFD , 35/5 MFD....etc
Oct 21, 2009 | Heating & Cooling
Ac motor hums and wont turn unless assisted manually
sounds like a bad capacitor its a little shiny can that is usually oval or round this gives it a kick start check the mfd rating (probably 3,4,5 mfd) and voltage (370 or 440) and replace the capacitor they are fairly inexspensive
Jul 29, 2009 | Fedders Appliance Air Conditioner Wall
Need to replace capacitor for comfortmaker model nac036akc3. the question is about the microfarrods and voltage of that dual capacitor
the mfd and volts should be printed on the outside of the capacitor the higher rating mfd is for the compressor and the lower for the fan
if there is no number on it there should be a mfd rating on the motor and compressor if i had to guess i would say for a 3ton system maybe a 35/5mfd 440v
if you are having that much trouble finding those numbers i would call a wholesale house for that unit and ask make sure you have your serial number too
hope this will help
Jul 29, 2009 | Heating & Cooling
Capacitor unable to read what size
If it's the condenser fan motor cap then look at the label on the fan motor for the size usally 3/5 mfd.
If its the compressor run cap then check the top of the compressor or the info. plate/sticker on the unit for the size of the cap. Let me know if you have any other questions.
Phil
Apr 10, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
215 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
