Question about Saeco Talea Ring Plus Espresso Machine
On turning on our Saeco Talea Ring m/c has message "priming circuit on" or similar and just pumps water through outlet. Only way found so far to stop the priming is by going to menu and pressing something like reset factory settings, but doesn't always work. Also water seems to be leaking slightly from at or near the reservoir as there is always a little water below machine on that side. In addition, steam outlet sometimes drips continuously after use, but this is intermittent in occurrence.
dutchman05
  • 487 Answers
SOURCE: Saeco Talea Ring Plus
ok with a machine you have already for a while :
Putt descaling solution in the machine. unplu the machine and open the watere valve. Aftre about 2 days it should have desolved.
BUT>>>>>>>>>> what also can be is that the valve on the bottom of the water tank is not working.
Fill it a little and wiggle the valve until water comes out and than try again.
Priming normally goes.
Water in tank. push water button and open valve.
Posted on Jun 03, 2008
mirran
  • 515 Answers
SOURCE: I have a Saeco Incanto
Do you have a filter in your water tank?
if you have a filter, remove it and try.
Posted on Jul 10, 2008
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
Clarification: It complains constantly. Even when I empty the drip tray, which is already empty, put it back in (empty) - it still wants me to "empty the drip tray" again. Sometimes - if I'm lucky - I can brew 1 espresso before it wants me to empty the drip tray.
Thank you for your assistance!
Posted on Jul 11, 2008
  • 74 Answers
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Posted on Jul 15, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco Odeo Giro Plus dripping steam wand
I don't know any of the suppliers in the UK, but yes the problem can be fixed at home, it is very easy to replace the steam valve, just make sure that you get the complete valve(body and tap rod). Try this site they might ship the parts to you (saecoparts.com)
Posted on Jun 13, 2009
What to do when prime water curcuit comes on
When prime water circuit comes on turn on the steam/water valve may need to select hot water the machine will run water until primed
Nov 16, 2014 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
How do u prime the pump for saeco talea giro plus expresso machine
Should be just a matter of switching the machine off, if it doesn't prime then switch off, leave a few minutes and try again *obviously making sure there's water in the tank....
Jul 16, 2014 | Saeco Talea Giro Espresso Machine
What is message "prime water circuit" not in
Fill the water tract with the water. For example - swith the steamer to hot water dispence and run water for several seconds (untill it goes smoothly).
Mar 18, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Aug 23, 2009 | Coffee Makers & Espresso Machines
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Doesn't start up properly...
Actually I decided to day to deliver to a service point for Saeco in Warsaw ,Poalnd.
Anyway ,thank's..
Best regards
Johnny
May 14, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
May 22, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Talea Ring Plus Espresso Machine Logo
54 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
