Question about HP Compaq Presario V2000 Notebook
Compaq v2000 dies after some time
I have a compaq v2000. It turns off suddenly by it self. This happens when ever hard drive is sppining fast or it has been processing continousely for about an hour such as gaming, videos and scanning the hard drive, I noticed it does not happen when it runs program which does not require too much computing power.
  • 1 more comment
  • arif khattak Aug 02, 2008
    Murdock,
    Thanks for your enquiry. The problem exists in both cases.
    Pyrhyc,
    Thanks for your analysis. I think you are guiding me in right direction. I have the feeling that the machine is shuting down when the fan sound increases and the machine is heating up....I will try to clean the fan and heat sink....One more information, I would like to share with you.....The machine shuts down with a click sound.....May be it helps you to have better understanding of problem...
    Thanks and regards,
    Arif
  • arif khattak Aug 06, 2008
    Dear Pyrhyc
    I cleaned the heat sink and Fan. There was dirt built up. After that my machine is running ok. Thanks alot for your help. I think my problem is solved
    Regards
    Arif
  • Murdock Grewar
    Murdock Grewar May 11, 2010
    Is this only on the battery? Or AC power?
    Genius:
  • 2,028 Answers
Is the machine getting hot when it shuts down? If so, then you may need to clean the fan and heat sink. A dust or dirt build up can hinder the cooling system performance allowing the machine to heat up to a level that kicks in the built in fail safes in order to keep from damaging the processor. Try cleaning them and let me know. We'll go from there.
Posted on Aug 01, 2008
I have a laptop HP Compaq 6720s and now I get the following code t.w. 0x4001001300001002 and when I will restarted the computer the message boot.mgr missing. What must I do?
That error means that the Boot Manager is Missing. This is usualy caused by either a failed hard drive, or a failed attempt at recovery. If you try to do a recovery and then suddenly halt the process, weather on purpose or due to somthing like power failure, then the first bit of the Recovery boot process, the BTMNGR, can be hosed. If this happens then your only option is to order recovery disks from the manufacturer and install the OS that way.
You might boot into bios (F10 on startup) and do a hard drive self test first to make sure you dont have a hard drive problem...
May 31, 2011 | HP Compaq 6720s Notebook
I was wiping the hard drive when the laptop
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
Mar 17, 2010 | HP Compaq Presario V2000 Notebook
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
Won't boot up, Hard drive self test result #1-07 Fail
Hi there.
The hard drive has failed and you will need to replace it.
If the laptop is under a year old take advantage of the warranty and send it in to be repaired for free.
Good luck and thanks for using FixYa!!
Apr 06, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 amd turion64
question.....does the motherboard you use support the powersource? that is one thing i would look into and have had problems with with many pc,laptops,etc. lemme know what happens
Aug 05, 2008 | HP Compaq Presario V2000 Notebook
Startup problem
This is generally an indication of a hard drive failure. You will most likely have to replace the hard drive.
Jul 23, 2008 | HP Compaq Presario V2000 Notebook
Laptop just went blank...cannot power up or turn on
try by resiting the ram, if the problem persits than your display adapter is having problem
May 19, 2008 | HP Compaq Presario V2000 Notebook
Laptop
Here is the manual for your laptop.
Turn to page 118 for directions on how to change the hard drive.
Dec 30, 2007 | HP Compaq Presario V2000 Notebook
Compaq v2000
Do u have installed recently, some software?
Try to boot up pressing the F8 button, when the menu appears select the option "Windows in safe mode" if u can boot to windows. View our software installed.
If it is not software try, boot whit the windows installation disk enter to the setup and select the option repair, u will go to a DOS prompted window (all black whit white letters) must appear "c:\"
used the command "chkdsk /f /r" let it run he will try to find any problem in the disk.
Nov 08, 2007 | HP Compaq Presario V2000 Notebook
Laptop shuts off every ten minutes
Probably the fact that the fan is not working at the correct speeds (faster when working on processes), because of probable deposits of sticky coffee is more than likely causing the shutdowns, especially if there is no screen warning coming up.
Nov 13, 2006 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
