Question about Coffee Makers & Espresso Machines
Coffee maker I'll go check but I've only had it for a few months. Where would this disconnection be? Inside the housing or on the outside?
  • 594 Answers
If yours does not have a bucket for the water than what you can do lift the lid where the water goes and loo to make sure there is nothing clogging it
Posted on Aug 01, 2008
No display, no errors, no help!!!
You need to check this site out Very Usefull, I went through the same thing with my ada8000 TOASTED TRANSFORMER no info . Here is solution.
http://blog.newyorkbrass.com/2010/07/07/what-does-a-neve-1073-and-a-behringer-ada-8000-have-in-common/
Jan 17, 2014 | Miele CVA4070 Coffee Maker
How do i get ants out of my coffee machine
First spray you house for bugs as this is not a good thing. Wipe unit with paper towel on the bottom section saturated with bug solution. Wait a Day and they will die. Wash surface and go.
May 02, 2012 | Keurig B60 Coffee Maker
We have model # BKC800XL - it give us a message about "descale" not sure what that means and how to correct
Just like any coffee or espresso maker, descaling is a process that needs to be done periodically. If your location has hard water, you may need to descale more often than elsewhere, but it's nothing to worry about. It's just a chemical process that occurs as the result of mineral deposits from the water collecting on the elements inside the coffee maker. I'm sure that coffee manufacturers will sell you tablets for descaling, but I've always just used undiluted white vinegar as the reactant. To do this, I recommend: 1. Empty all of the water from the reservoir. 2. Fill with undiluted white vinegar. 3. For this type of coffee maker, brew as many cups as it takes to empty the reservoir, being sure to dump each cup in the sink as it finishes. 4. Once you've run through all of the vinegar from the reservoir, refill with water and run a few cycles to rinse. (You may want to leave the water to soak for a while to give the residual vinegar further time to clean off the minerals.) 5. Fill again with water and rinse. 6. Once you've emptied the reservoir a second time with the water, your machine should be adequately descaled and ready to brew coffee again!
Jun 17, 2011 | Keurig B60 Coffee Maker
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a black and decker ODC450 coffee maker where the display went blank and it will not work at all. Any ideas?
This could signify water damage so be careful!!
If the machine smells slightly like burning plastic, DON'T use it. take it in to your local electrician to have a look.
If you think its ok...
Check your house power, Change to another power point, check your house fuse box, if this is not the problem then DISCONNECT the coffee machine from the wall, take off the back cover or bottom and look for a fuse to replace.
Take care
Regards
Ian
Nov 03, 2010 | Black & Decker SpaceMaker ODC150 Coffee...
Water does not go thru
If the machine is at least a few months old and slowly got to this point you may need to get 2 quarts of white vinegar and run it fhru 2 or 3 times to clean out the inside (use a filter and just run it back thru) Good idea to set it outside for this since it smells kinda bad. Be sure to rinse at least 3 times before making coffee. But first do you have power to the unit, be sure about this. Can you tell if the heating element is working and heating the water.?
Jun 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Not heating up still cold
I had the same problem after only a few months. There is a float at the side of the water resivour, this float also has a magnet attached to it and for some reason becomes lodged at the bottom of the tank, telling the machine that there is not enough water in the tank, even when there is. Use a magnet on the outside of the resviour, connect it to the one on the inside and lift very slowly upwards...Hey presto the light stops flashing and the water boils
Aug 03, 2009 | Philips Senseo HD-7810 Coffee Maker
Grounds splash from basket into carafe
My brother has a Bunn that does the same. I think the coffee filters he is using are too short. If you think this might be the problem too, try an internet search for Bunn coffee filters. Hope this helps!
Jun 19, 2007 | Bunn GR10 Coffee Maker
Coffee Makers & Espresso Machines Logo
93 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
