Question about RCA M4204 MP3 Player
Usb port broke and missing which doesn't turn on, this happen because when i would charge the mp3 it would hang and get loosen until it came off,i' vied took it aprt but nothing so i been looking for someone to fix it..
  • 15 Answers
You can buy a new USB female connector and solder it on the PCB of your MP3 player.
You will need a female Mini-USB Type B connector, a soldering iron with a fine tip, flux and some solder wire.
1. Open the case of the MP3 player and look for the spot the lost USB connector was soldered on. 2. Clean the pads with a cotton swab and some clear alcohol. 3. Clean the female USB connector using the same method. 4. Heat up the soldering iron to a moderate temparature. 5. Put some flux on the solder pads. 6. Place the female USB connector on the pads and solder it on by touching the soldering iron and the solder wire on the pads until a tiny drop of solder makes the connection. The solder should flow on the pads because of the flux. 7. Re-assemble the MP3 player.
You can then test the connection using a multimeter.
Posted on Mar 15, 2011
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    When you plug the reader in to recharge is a red light supposed to come on until charged? How do you know when it is fully charged?
    Yes, the red light should be turned ON after connecting the Reader to te Computer. That means the Reader is taking charge. After getting it fully charged, the red light will be turned ON. If those things will not happen to your reader, perform the below mentioned stepos::
    1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
    Feb 02, 2010 | Sony E-reader Portable E-book MP3 Player
    Hanging problem
    ya u are rite connect the cable thr will show that mtp connected then transfer music but is it hanged on than this means ur usb port has problem than try to use different usb port...make it sure u are using rear usb port of ur pc.....hanging problem is only due to breakage in transfer of data that is only due to low usb port...i have same problem i always connect my media player in front usb port of pc then i got to know that it has low speed than i connect it to rear of usb port in my pc that is high speed port than it worked smoothly
    Sep 02, 2008 | Samsung YP-K5JAB MP3 Player
    Mp3 insignia sport
    is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
    if no hub try a different usb port or a different cable
    Aug 10, 2008 | Insignia NS-DV2G MP3 Player
    No charge...
    Hello mandag78,
    The error message you are talking about occurs when a device tries to draw more power from the USB port then the port can provide,
    Make sure you are connecting the MP3 player directly to a USB port on the computer or a USB hub that has an independent power source (one that you plug into an electrical outlet). If you are plugging your MP3 player into a USB keyboard or a non-powered hub the port may not have enough ower to charge it.
    I am assuming tha tthe Zen was working before? And that you are sing the exact same USB port and cord that you were using to charge the item previously? If so, then what you are experiencing might be a sign that the unit has failed and is in need of repair.
    Best Regards,
    Ken
    "Go Ahead. Use Us."
    Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Charger
    Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
    -Tha Mp3 Doctor
    Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
    SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
    hii
    just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
    let me know what happnes..
    tc
    May 28, 2008 | SanDisk Sansa MP3 Player
    Nano Will Charge on Laptop/ Will Not Sync & Will Not Connect to Itunes
    Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
    http://www.apple.com/support/ipod/five_rs/
    Mar 19, 2008 | Apple iPod nano
    RCA M4204  MP3 Player Logo
    65 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
