Question about Danby Dryers
My new dryer drum is "stuck" It wont spin, just hums
    President:
  • 3,074 Answers
Either the belt is broken or off. If this is a new dryer I would contact the people you bought it from as if you open it up to look/fix it they may say you broke it. If they will not fix it here is a website that will assist you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 15, 2011
Dryer motor hums but doesn't spin
Sounds like the motor has gone bad.
May 10, 2015 | Amana Dryers
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Motor seems to be stuck drum wont turn when i cut it on
does it hum when u turn it on can u spin the drum by hand can u hear the motor running u may just have a broke belt
Jan 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer wont start, makes a humming noise. I have to manualy turn the drum then the dryer will start
Check the belt to see if it is worn or loose. If it has a capacitor start motor, the capacitor or motor could be going bad also. If the motor is spinning but the belt is not turning then you have a loose belt.
Jun 14, 2010 | LG DLE2532W Electric Dryer
Dryer wont spin, motor making humming sound
sounds like the motor is bad,try turning the drum by hand,if it's hard to turn there could be something stuck in the blower wheel or the belt is jammed on something or the motor is bad
Feb 19, 2010 | Kenmore 800 7983 Dryer
We just purchased a new Samsung Dryer model #DV218AEB/XAA the lights will come on but when you attempt to start the dryer there is a hum, the dryer does not spin, then the hum goes away after a few...
Could be a couple things causing this problem. If you can turn the durm by hand without much resistance then the belt may be too loose. This could be because the spring on the tension pully came off or the belt streached. The humming you hear is the motor spinning. If you cannot turn the drum by hand then something could be stuck between the drum and the frame of the dryer.
I would also check that the dryer is wired correctly, because low voltage could be causing the motor to hum but not turn.
Dec 23, 2009 | Samsung DV218AEW Electric Dryer
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
I have a performa dryer and when you push the start button it just hums but won't stay on.
there is a good chance you have something stuck in the blower motor, you can take a peek down the lint trap with a flashlight, you can also confirm this simply by trying to trun the dryer drum,
try to spin it by hand, if it wont trun, or has a great deal odf resistance then you have a sock stuck
if it does turn easily, then hold the door switch
and try to turn the drum as you hear the hum
if this starts the dryer and all is good, till you let go of the door switch,, well then it sounds like you have a motor issue, a start winding is bad, to be more specific.
Oct 19, 2009 | Dryers
Dryers Logo
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
