Question about Acer S201HL Monitor
The words on the screen are blurry but i increased the focus and it didnt fix it nor changing the aspect ratio.
    Problem Solver:
  • 14 Answers
If your computer uses the Windows 7 operating system, the problem could be in your current display theme. You can try the advice in this article from Visualpawn.com to see if it helps.
Posted on Sep 12, 2012
    Problem Solver:
  • 27 Answers
There is a magnetic rings on the neck of the crt you can turn them carfully
Posted on Mar 18, 2011
Daewoo DTQ-19TV1fc aspect ratio changed to letterbox. How do I restore it to full screen?
get the on screen menu on the screen
scroll around till you see aspect ratio and click on that use the buttons to change ( you will see the changes on the screen)
click ok and exit when satisfied
Fir aspect ration to change there can be a few reasons
some tv stations produce movies in the wrong ratio and it shows up for the movie as black edges or tall figures or fat figures ( change channel to verify)
or there can be a fault occurring in the board of the set that will not hold preset aspect ratios
Oct 26, 2015 | Daewoo Televison & Video
How do I stop the words from being cutoff on the tv screen?
You need to check the zoom or aspect ratio on your TV remote and or your cable/satellite remote. The zoom or 16:1 aspect ratio often cuts off words if the movie or show is in 4:3 ratio.
Jan 04, 2015 | Panasonic Viera TC-P50S1
How do I stop the aspect ratio from auto changing on my flat screen set up as the monitor for my computer?
When you set it to just scan the source will determine the scan. I would remove the bose from the unit and connect the cable or sat box directly to the hdmi in of the tv. if the problem persists check Samsung web site for software upgrade. If upgrade does not fix replace the main circuit board.
May 07, 2014 | Samsung Televison & Video
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
Picture is cutting off top of subjects head. Can't see wording at bottom on screen
The aspect ratio is not set up right. It is a menu thing and you will have to make the change on screen with your remote. Find the list for the picture and go through the menu, look for aspect ratio or screen size.
Feb 09, 2010 | LG 32LG30 32 in. LCD HDTV
The picture on my LCD 52" 650 series TV makes everyone look short
There is an aspect ratio setting in your menu options. You will have to change the aspect ratio so you get a normal screen.
This will most likely fix your problem.
If by slight chance it doesn't, you will have to remove the back of the tv and find the manuyal adjustments for it.
All newer Tv's have the aspect ratio/picture change setting.
Jan 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
My tv the picture is bigger than the tv screen
it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
Oct 20, 2008 | Akai PT4298HD Rear Projection Television
Aspect ratio
increase the resolution to the maximum then check
Apr 17, 2008 | ASUS LCD Monitor
Prob. with aspect ratio
The key word here is dropped,was the unit ok before? how hard was it dropped? if the tv is only a 4:3 screen then it can not give you a 16:9 AR unless the dvd can change that, it probably has the main circuit board broken somewhere and it needs professional help.Let's hope is not major damage.
Sep 19, 2006 | JVC AV-27D303 27" TV
Acer S201HL Monitor Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
