Question about Mitsubishi WS48511 48" Rear Projection Television
Fast flashing green timer light - Mitsubishi WS48511 48" Rear Projection Television
  • Mitsubishi Master
  • 8,617 Answers
Replace the DM capacitors. You can get the DM repair kit for your model from www.tvrepairworld.com which has the upgraded capacitors and the CD with repair instructions.
Posted on Mar 18, 2011
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: flashing green timer light on TV
change the 4 100uf capacitors on the DM board. You will need the service manual to get the set apart as its technical. But with the service manual and take notes you should be able to repair it. But the service manual for that chassis is mandatory or you will never get the chassis out without alot of trouble. Heres a link where you can get the manual emailed to you.
http://servicemanuals.vstore.ca/
Posted on Mar 20, 2008
experttv
  • 203 Answers
SOURCE: mitsubishi wd52527
does the light flash for 1 min then pause for a second then blink for another min?
Posted on Oct 18, 2008
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Fast flash timer light
A fast flash indicator is an error code of some sort. Possibly your projection lamp timer indicated a lamp chnage required?
Aug 15, 2010 | Mitsubishi WS-55859 55" Rear Projection...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Mitsubishi wd52527
Oct 18, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WS48511 48" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
