Question about Magnum Air 8 10 Gauge Framing Nailer
I recently bent my magazine on my magnum air framing gun. I was wondering where I would find the magazine to fix it or if it would be better to replace the gun?
  • 2,176 Answers
Depending on how bad it is bent the magazine is usually rather expensive. The way we used to "straighten" some is to take a block of wood and strike the end of the magazine against it to pull a slight bend out of the magazine so it was usuable. Put the end of the wood on the ground and hold it in place with your feet and hit the end against it, checking for the best alignment. This only works if the bend is not severe. If you give me the exact model and brand I will try and find a source for the part also. Let me know if you need more assistance.
Posted on Mar 16, 2011
Why does my Senco SN 901 XP frame nailers driver stay forward?
not sure what powers the senco if it works on combustion or air could be damage O rings. Another possibility is a trapped nail under the blade. Have seen where a nail has not been driven out of the magazine but has bent and points down the magazine close to end of gun. What happens is the blade drives over the nail but becomes trapped between nail and roof of the nose assy. Probably need to strip the gun a little.
Mar 24, 2014 | Tools & Hardware - Others
I have a magnum air 33degree gun, i removed the head cap to replace blown gasket, when i put it back on the gun will not fire.
Check the alignment of the of the gasket in reference to the small hole on the sealing edge(gasket has four bolt holes and one vent hole). This small hole allows air to vent from the upper part of the head when you depress the trigger casuing the gun to fire. If the gasket seals the hole or if air is leaking past the orings in the head vale the gun will not fire. If you hear air leaking from trigger when you attempt to fire the gun, most likely orings are not sealing. Remove the headvalve and lube the orings. If no air leaks from trigger when your attempt to fire, vent hole blocked. Good luck with your repair.
Aug 27, 2012 | Magnum Air 8 10 Gauge Framing Nailer
I have a Magnum Air framing nailer with a blown out gasket. Does anyone know where you can get parts for these?
Belive it or not you can get all of or at least most of these parts at a good hareware store . Air nailers are all Orings if you can take it apart then take the Orings with you match them up exactly it may cost you 2 or 3 dollars to completely rebuild this gun i have about 10 differant nailers and do this when ever one sticks . Put a water trap on your compresser and shout some WD40 into the air inlet on the gun before you use it and this will make the gun last much longer
Jun 05, 2011 | Magnum Air 8 10 Gauge Framing Nailer
I bought an older model Magnum Pro air nailer . We tried it out at the store and it shot fine but I didn't find out how much air pressure to use. Can you tell me how much and how often to oil the nailer?
Air requirement: 8 to 10 CFM @ 70 to 120 PSI, Air inlet: 1/4" - 18 NPT
and i would try to oil it regularly depending on the air supply if you use a older air supply it might condencate water a little more a newer unit might also have a water remover on it. Just a drop or two before use should keep the gun in good condition
Feb 26, 2011 | Magnum Air 8 10 Gauge Framing Nailer
Paslode gun will not engage the fan when tip depressed
if this is the framer, could be quite a few things. first do you have nails in the magazine, the safety might be bent not allowing full travel, the spark unit might be faulty. If you are comfortable with some partial disassembly, let me know and I will go into further detail for you on troubleshooting, you will need an allen wrench the size of the cap head screws. Let me know
Oct 03, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I am trying to find extra magazines for my mossberg .22 magnum rifle bolt action, also am wondering how hard it is going to be to find parts for a weaver scope....????
Gunparts.com has the mags, the scope parts, I don't know, you would have better luck finding an old scope for the parts.
Feb 13, 2010 | Weaver Optics
I have a craftsman nailer full head framing gun. There is a jam of 2 nails in the cylinder. How do you unjam the gun
On that nailer, you have to remove the nail Magazine. And then clear jam thru the sloted open side. And then put the Magazine back on. Usually one big bolt on each side of the nose and 1 or 2 bolts on the rear body.
Aug 25, 2009 | Air Tools & Compressors
Magnum Air 8 10 Gauge Framing Nailer Logo
184 people viewed this question
Top Magnum Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Magnum Air Tool and Compressor Expert? Answer questions, earn points and help others
