Question about Garden
What oil should i use in my honda 5.5 gx160 generator
  • 59 Answers
30w lawnmower oil..... them things will run on most engine oils though, i never have any problems with any of mine.
Posted on Mar 15, 2011
Can I use 10/40w motorcycle oil in my Honda gx160
you could but I strongly suggest that you use the correct oil as bikes need special oils for reliability.
all it takes is a call to a honda service dealer to get the correct information
Aug 24, 2015 | Honda Vehicle Parts & Accessories
What is the proper level on the dip stick for the oil?
There should be an area on the stick with cross marks on it. Try to fill it to the upper part of that cross hatch section
Feb 27, 2015 | Pramac ES3000 Alternating Generator With...
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
Aug 19, 2012 | 5.5 HP GX160 Engine
My honda 5.5 gx160 generator wont start
Is the ignition switch turned to "ON" . Is it full of oil?
Apr 23, 2012 | Honda Horizontal Engine 5.5 HP OHV 12V ES...
Honda gx 140 will start but dies right away wont keep running
check the oil level and top it up its most liky low and low oil shutdown is kicking in
if it still wont run try checking main jet , then try cleaning out carb and replacing plug
then check for tight in / ex valve s
cheers
Sep 07, 2010 | Multiquip GA25H 25kW 120V Honda GX160
I have a honda gx160 5.5 generator will not start with the, i believe oil sensor plugged into the turn off switch oil level ok will i need to change the sensor also is this a big job.
i have never bothered to change onebecause you need to strip the motor,that is not realy such a big job if you have done a few ,but you just need to check the oil when you fill the gas tank , thatis simple enough . the oil alert is realy a gimmick for the dummies, it only takes 10 secs. to chech the oil manually
Dec 31, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Faulty Generator
check for open armature (check continuity at slip rings). Also check that diodes are good (not opened). Engine RPMs should be at least 1800 or 3600 depending on alternator. Probably 3600 RPM (for 60hz).
Also check to see if you have a bad circuit breaker.
Dec 07, 2009 | Electrical Supplies
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Garden Logo
326 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
