Question about Samsung Computers & Internet
Hi, I plug it in wit the usb and I hear a melody come out of it repeatedly until it quickly stops and then then light on the drive flashes 3 times then stops and then does the same again, and so on and so forth. The drive isn't even read by windows (XP nor Vista) and disk manager doestn' see it either. Need to fix this quick. It's been 3 days already! Please help me with any advice if you can. I don't have the money for data recovery professional...
    President:
  • 1,623 Answers
Is the hard drive powered by the USB lead, i.e. it has no seperate power supply plugged into it? If it is powered by USB then maybe you should unplug your other USB devices and allow the laptop/PC to give it the power it needs, then it will work
Posted on Mar 15, 2011
How to get alarm to stop blinking after replacing water filter
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Dec 03, 2015 | Fagor FQ9925XUS
Error Code? 2011 Mazda 3 Sport Airbag Light Flashing.
suggest you get it to Mazda to have problem diagnosed - your safety system could be compromised
Dec 17, 2014 | 2011 Mazda 3 Sport
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
    All you have to do is
    Step One
    To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
    1. Download and install EASEUS Data Recovery
    2. Insert micro SD
    3. Open EASEUS Data Recovery, choose Complete Recovery - Next
    4. Select the drive micro SD - Next
    5. Save the data to the hard disk (max. 1GB)
    6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
    After all data is secure, do the process repair micro SD
    Step Two
    The first alternative - use the software HP Drive Key Boot Utility
    Using the HP Drive Key Boot Utility, for Win XP
    1. Download and install the software HP Drive Key Boot Utility
    2. Then, double click the file cp006049.exe - select Install.
    3. Insert micro SD
    4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
    5. Remove the micro SD from the USB port, then insert it again.
    6. Quick format micro SD (FAT file system)
    7. Restore all data, to the micro SD.
    Using the HP Drive Key Boot Utility, for Win Vista or Seven
    2. Then, double click the file cp006049.exe - select Extract
    3. Insert micro SD
    4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
    The second alternative - use software HDD Low Level Format Tool
    1. Download and install HDD Low Level Format Tool
    2. Insert micro SD
    3. Open program HDD Low Level Format Tool, select micro SD - continue
    4. Click S.M.A.R.T - click Get Smart Attributes
    5. Click LOW LEVEL FORMAT - click Format this device
    6. Wait until the process is complete - press OK
    7. Remove the micro SD from the USB port, then insert it again.
    8. Quick format micro SD (FAT file system)
    9. Restore all data, to the micro SD.
    I hope this information helps.
    Oct 15, 2011 | SanDisk 2GB microSD Memory Card
    Sudenly kingstone usb changed to skymedi and doesnt formated
    When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
    How to save data
    To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
    Repair flash drive Kingston
    1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
    2. Format from Administrative Tools.
    Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
    Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
    3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
    4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
    How to install the HP Drive Key Boot Utility to the operating system
    Win XP: double click the file cp006049.exe - select Install
    Win Vista & 7: double click the file cp006049.exe - select extract
    How to use the software HP Drive Key Boot Utility
    For Win XP, first way
    Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
    For Win XP, second way
    Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
    For Win Vista & 7, first way
    Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
    For Win Vista & 7, second way
    Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
    Description
    initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
    How to restore the capacity of flash drive Kingston
    Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
    Hope it helps.
    Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
    Want to silent keypad when typing or dialing
    Hi nanro346,
    Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
    Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
    My playstation 3 wont play sound through the hdmi cord (it used to until the other day when it just stopped) and then we plugged it in with an AV cord and it was playing the sound but there was no picture?...
    2 things:
    1st try doing a system restore in safe mode and rebuilding data.
    2nd Instead of doing a quick recovery do a full recovery.
    SAFE MODE:
    1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
    2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
    3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
    NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
    Good Luck!
    Feb 21, 2011 | Sony Playstation 3 (PS3) Console
    Clean light keeps blinking...how do i reset?
    it's telling u you have a fault but to clear it just press ur start button until the washer beeps then shut the door and leave shut until the aplliance stops. it will be ready to use. The flashes are usually intermittant i.e 3 quick flashes then a small break then 3 flashes again this process will repeat over and over. Count the flashes and let me know the amount i'll look at the fault for you
    Hope this helps
    Mar 19, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
    How to set up yobo controllers for ps3
    I just bought a used one today and took me a little while to get it to work. Plug the USB receiver in and turn on the PS3. Press the Mode button and the lights will flash repeatedly at a fast rate (it's searching for the receiver). When it finds the USB receiver, the lights will still flash, but slower than before. When they're doing this, press the mode button again, and that should be all that you have to do. You can also plug the receiver in USB slot one, the charge cable in slot 2, and do the steps to set it up to make it work while charging. (I tried taking the receiver out while charging, and the lights started flashing again so I guess the USB receiver has to be in at all times)
    Jan 11, 2009 | YOBO FC Game Console
    My thomson dtr
    just found this solution and it worked for me ............. though it wiped the hard drive ............ basically restores to factory settings
    turn all power off and back on again press stand by button repeatedly until flashing amber light is n constant them quickly press up down left right in that order as quick as you can .............
    good luck
    Nov 11, 2008 | Televison & Video
    Computers & Internet Logo
    95 people viewed this question
    Top Samsung Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
