Question about SE3010 2003010 Amp Manual Starter and Charger
Looking for a repacement part. Need new switch, numbers on part are CA0297, 25A 120-240 VAC, 0499000022, DYU-39-01, defond...amoung others. Can yoy please help me?
    Problem Solver:
  • 6 Answers
See here:
Posted on Sep 22, 2013
Who sells a Defond CYCM-1213-A rotary switch for a Toro Garden Blower/ Vacuum
Ebay has listing for Defond switches. Don't know if they carry that specific model number.
May 29, 2015 | Toro Garden
What is a Defond-2113?
Defond is a manufacturer of the Switch
Nov 15, 2014 | Garden
Where can I buy a Defond CPU-2113 safety switch for a Toro Blower/Vacuum?
If you do not use the Blower / Vac for Vac you can cut out the the reset switch, it's only when you get foreign material in the impeller using the Vac stopping the motor, I cut out the switch. As you look at the Defond switch (side with writing you see a white wire and a black wire side by side. mark the black wire with a small piece of tape 1-1/2 inches from the connecting lug. Cut all wires off the switch. Strip wires back 3/8 to 1/2 inches. Use heat shrink tubing
and slide it back on the black wire with the tape, same thing thing with the black wires on opposite side of the switch. Use a end to end splice as opposed to a parallel splice because of wire routing space..Splice the white wire with the black with tape, Then the other two black wires. using heat shrink tubing to cover the splice. Good idea to take a picture (smart phone) so as to see wire routing after you separate blower halves, very little wire routing space. Make sure motor is seated in it's nest before joining halves together do not use Vac if you use this fix. Mine works just fine, save $60+ bucks.
Nov 01, 2014 | Toro Garden
I need 1 switch DEFOND 1513a
What are you asking?
Jun 14, 2012 | Cars & Trucks
Looking for a source to purchase Defond CPU-2113 replacement switch for Toro Blower Model 51599. I live in Omaha, Nebraska.
I can offer it. drop me a memo send the Defond drawing and the quanitity to: roman dot xiao at gmail dot com
Jan 07, 2011 | Garden
I have a lakewood window box fan model hv-18-wr it has a defond 6a 120 vac rotory sw type dye-3606 with 3 speed forward and three reverse and an off. the motor is a samsung model hv-18-wr(lw.3v) s/n...
did you take the out the old switch/ if not follow the colors to the switch and to the motor. you will find numbers on the switch, the wires coming off the motor go into the switch, if you have the light and the switch that run the temperature you can take that out and just run the wires direct to the switch and follow them up from the motor to your switch and like i said red wire, blue wire,white wire,orange wire,brown wire,yellow wire,2 black wires,you should have these wires coming off the motor and they go to the switch,the front of the switch has these number on front A in upper left and on the right side S 2 the bottom left side should have S 1 and the right side of the bottom should have B, you will need a small screwdriver to push the small metal plate that hold the wire in , just push light in the hold and the wire will come out, make a map of what wire go wear and you in a new fan.if you took it apart already then i have to tell what color go wear on the switch from the motor.
Aug 30, 2009 | Dryers
Lakewood 7096
i went all over town looking for a switch. finally found two lighted switches at grainger carling technology part no. 1A824. ground down the outsides glued both together jumped across top and bottom terminal with copper wire and it seems to work fine now.only time will tell. i hate our throw away society which the junk imported in from china seems to foster.
Jan 07, 2008 | Lakewood Oil-Filled Electric Radiator...
Salton expresso cappaccino maker microswitch
The Honeywell V7-1C17E9 microswitch is a form/fit replacement for this Defond switch. You can get it at www.alliedelec.com. I had one fail in a Delta DT1600E Pressure Washer. The replacement switch worked great. Good luck.
Oct 26, 2007 | Coffee Makers & Espresso Machines
Window Fan switch bad
Steve, Your fan model is HV-18-WR; I have 2 with the same problem. I can't find a source for DYE-3606 switches either. Here is one source for rotary switches; one might be suitable: http://www.alliedelec.com/Catalog/Indices/Products.asp?sid=46BBAA8076DBE17F&N=4294828748 I can draw a diagram of how the existing switch is connected, but I don't know how that would translate to a replacement switch.
May 22, 2007 | Lakewood HV12WR Window Mount Fan
SE3010 2003010 Amp Manual Starter and Charger Logo
464 people viewed this question
Top Schumacher Vehicle Parts & Accessories Experts
Ruben Diaz
treeeee
treeeee
Rigger
Are you a Schumacher Vehicle Part and Accessory Expert? Answer questions, earn points and help others
