Question about Hotpoint Washing Machines
Does not spin - Hotpoint Washing Machines
    Master:
  • 414 Answers
Most likely a broken or cracked lid switch. If this occurs an upright machine will not
spin. The model number is located on the inside of the lid at the back.
Usually you can remove two screws at each end of the control panel and tilt
it back to expose the plug that the lid switch connects to.
the switch will have two screws holding it as well as a ground to the
chassis. (The screws should all be #2 phillips and the ground is a 5/16 socket)
tilt the drum towards you to make access easier. The wires are routed in guides which
are clipped to the chassis. The ground is the hardest to remove as it is usually
towards the back of the machine. You can order the part online or if you have
an appliance parts store nearby, they will generally sell this over-the-counter.
Hope this helps.
Posted on Mar 15, 2011
  • 59 Answers
One of the problems could be the pump. sometimes a coin gets jammed in there stopping it. if the machine will not drain water then it will not cycle to spin.
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
it it is not slapping in when it goes to spin , it will not spin
Dec 18, 2015 | Samsung Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Will not spin on spin cycle
Brian...You have a Non-compliant washer! Brian...You need to replace and Install a New Drain Pump! She will Spin, Spin, Spin all day long afterwards~
Jan 20, 2014 | Whirlpool Washing Machines
Not spinning on spin cycle
No spin is electrical!
Nov 28, 2012 | Washing Machines
Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
1) may be your spinning cloth load over.
2) Check inside the container (space of wall & spin tube) cloth may be inside.
3) Door stopper (Brake) position not correct.
Actually the spin motor starting slowly first.
Mar 26, 2011 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
