Question about Health & Beauty
Where is the proper location to install the nikko gpact and yhe lp relay flasher.
  • 35 Answers
It usually fits to the left of the alternating switching flanger, use 4mm thrust clips to retain.
Posted on Mar 15, 2011
Fog lights 03 gmc envoy slt not working. How can i located fuse without
There is also a relay ! FOG LP fuse # 11 10 amp location , under hood in the engine bay fuse / relay box . FOG LP relay #39 .
RR FOG LP relay #45 , RR FOG fuse #5 10 amp , location rear fuse box .
The fog lamp relays are computer controlled , by BCM
Mar 27, 2017 | 2003 GMC Envoy
2004 honda odyssey flasher unit relay location how do you install a flasher relay in 2004 honda odyssey
Your vehicle might not have a flasher relay.
Vehicles using a CAN-bus system often use a single ECU to carry out all vehicle functions where timing is required - flashers and hazard flashers, courtesy light, wiper delay, etc.
I suggest you check a wiring diagram for your car to discover what system it has.
Oct 23, 2016 | 2004 Honda Odyssey
How do to replace a flasher in a 2001 pt cruiser
Signal Flasher Location - PT Cruiser Forum
www.ptcruiserlinks.com > ... > Tech & Performance Forum
Nov 10, 2010 - 10 posts - ‎4 authors
I have installed LED turn signal lamps in my 09 PT. ... Seems the flasher relay location for 2001-2005 is different of the 2006-2010 PTs. Turn signals not working
Dec 27, 2011
Replace Multifunction Switch w/fog lamps
Jun 27, 2007
PT turn signals (or lack of)
Mar 17, 2005
Turn Signals Not Working
Jun 20, 2004
More results from www.ptcruiserlinks.com
how to replace the turn signal flasher on a 02 ... - YouTube
? 5:35
https://www.youtube.com/watch?v=ikJHh7OLcXg
Aug 16, 2009 - Uploaded by bguess
HOW TO REPLACE THE TURN SIGNAL FLASHER ON A 02 .....Replacing flasher/turn signal relay on a ...
FLASHER RELAY - 2001 Chrysler PT Cruiser - RepairPal
repairpal.com > ... > Chrysler > PT Cruiser > 2001 Chrysler PT Cruiser
Feb 9, 2011 - FLASHER RELAY on 2001 Chrysler PT Cruiser. WHERE ARE THE TURN AND HASZAD RELAYS LOCATED. by moposse in Des Moines, ...
Nov 26, 2015 | Chrysler 2001 PT Cruiser Limited
Where is the flasher relay on a 2002 lancer
The turn signal and hazard flasher unit is located in the interior fuse panel located under the driver's left side knee protector. They are replaced by simply pulling them straight out. Note that the prongs are arranged in such a way that the flasher must be properly oriented before attempting to install it. Turn the flasher until the orientation of the prongs is correct and simply push it firmly in until the prongs are fully engaged.
Hope this helps (remember to rating this free answer).
Oct 12, 2011 | 1989 Acura Legend
Location diagram for1996 chev blazer turn signal flasher unit
Flashers: The convenience center is used to centrally locate various buzzers, relays, flashers and/or circuit breakers. The turn signal and hazard flasher units are usually located in the convenience center located just below the instrument panel on the drivers side. Replace the flasher by unplugging the old one and plugging in the new one. Confirm proper flasher operation.
Hope helps.
Aug 16, 2010 | Chevrolet Blazer Cars & Trucks
91 Chevy K5 Blazer turn signal flasher
located under the instrument panel to the left of the steering column. The fuse block should be visible from underneath the steering column, near the pedal bracket.
Some models may use an underhood fuse/relay panel
If the panel is not visible, check for a removable compartment door or trim panel which may used on later models to hide the block. This panel is usually located on the left end of the instrument panel.
The convenience center is located just below the instrument panel on the drivers side. It contains individual relays such as the seat belt and ignition key alarm, and flasher.
On newer model vehicles there is an underhood fuse/relay center contains both mini and maxi fuses, as well as some relays.
Replacement The turn signal and hazard flasher units are usually located in the convenience center located just below the instrument panel on the drivers side. Replace the flasher by unplugging the old one and plugging in the new one. Confirm proper flasher operation.
Nov 03, 2009 | 1991 Chevrolet S-10 Blazer
Can't locate the turn signal flasher
Fig. 1: Some models may use an underhood fuse/relay panel
Fig. 2: Fuse panel cover-1991 model shown
Hope helped with this (remember rated this help) Good luck.
Nov 03, 2009 | 1991 Chevrolet C1500
FUZE BOX DIAGRAM FOR 1990 MERCURY TOPAZ
Replacement
  1. Access the fuse panel from the left of the steering column.
  2. Locate the blown fuse and pull out. DO NOT TWIST.
  3. Take note of the ampre number written on the top of the fuse. To install:
  4. Push a new fuse of the same ampre into the receptacle, making sure the contact is being made on both sides of the fuse.
LOCATIONS Headlights and Highbeam Indicator
  • One 18 amp circuit breaker (22 amp in 1987 vehicles) incorporated in the lighting switch.
Front and Rear Marker, Side Parking, Rear and License Lamps
  • One 15 amp circuit breaker incorporated in the lighting switch.
Windshield Wiper
  • One 4 1⁄2 amp circuit breaker located in the windshield wiper switch.
Power Windows
  • Two 20 amp circuit breakers located in the starter relay and the fuse block.
Power Seats and Power Door Locks
  • One 20 amp circuit breaker located in the fuse block.
Hazard Flasher REMOVAL & INSTALLATION NOTE: The hazard warning flasher is located on the rear side of the fuse panel.
  1. Locate the hazard flasher in the fuse panel.
  2. Pull the flasher out. DO NOT TWIST. To install:
  3. Push new flasher into place making sure a good contact is made with both terminals.
  4. Test flasher to make sure they function properly.
Various Relays LOCATION Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Fig. 1: Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal
This is the best info I could find....I hope this helps ya!
Jul 23, 2009 | Mercury Topaz Cars & Trucks
Where do I install the turn signal relay on a 1998 Volkswagen Cabrio? The right turn signal is flashing very quickly. I've replaced the bulbs. The left turn signal works fine. Thanks, Joyce
From what you say in your post, I can tell you it is not the flasher... the symptom you describe is due to either a wire fault (a short) or one of your bulbs on the right side is incorrect. The relay is located under the drivers side dash above the fuses (listen for the clicking of the flasher) and you may actually be able to feel the proper relay "clicking"... Hope this helps...;-)
Apr 13, 2009 | 1998 Volkswagen Cabrio
Health & Beauty Logo
19 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
