Question about Schwinn 26in Women's Mirada Bicycle
How do you install a drink cage and a basket ?
    Problem Solver:
  • 16 Answers
Installation of water bottle holder is simple. It usually mounts using the two screws on the top of the tube leading to the pedals of the frame. Remove these screws from the frame using a 4mm or 5mm allen wrench, place the holder over these holes, and rescrew in the bolts.
Installation of the basket is dependent on the model and location of the basket. However, all will mount to the frame(in the back) or fork of the bike on bosses.
Posted on Mar 16, 2011
How do i empty the inner basket of water
It should be emptied by the pump. If not ,there is a clog somewhere between pump and sewer drain. I would check the pump filter cage, and all the hoses after that. I believe you will find the solution for your question. GOOD LUCK FRIEND.
Mar 02, 2015 | Kenmore Oasis HT High-Efficiency 4.6 cu....
My female cat whose name is Batgirl does this to"drink" her milk and water. She is a shelter rescue I just wonder why she does this
It looks like OCD to me. Have you tried a more shallow dish which will alow him to reach the water with his tounge?
Feb 24, 2013 | Pets - Others
Where can i buy a bingo set for my kids? i want one where the balls actually roll around in a basket.
I've seen bingo sets on Amazon. They look very cute as they have the balls in a metal basket with a handle that spins it around and it doesn't seem expensive;
http://www.amazon.com/Deluxe-Wire-Cage-Bingo-Set/dp/B000F0GXTM
Jan 17, 2013 | Games
Stripped threads in accessory holder for cannondale ultra.. How do I remove old ones and install new.. Drink holder won't tighten down due to bad threads.. Any ideas
I am assuming you are talking about the bolts in the frame for the water bottle holders. You can take it to the bike shop and have them install a "Rivnut." This entails drilling out the frame boss that is stripped, and installing a Rivnut with is a rivet that is threaded for a specific size, in this case, the same size for cage bolts. Or you could order the kit and tools yourself, but then you would be left with extra Rivnuts and tools.
Dec 09, 2012 | Cannondale Bad Boy Ultra
Out of all the types of muzzles, why get a wire muzzle?
Wire basket muzzles are my personal preference for my dogs. They allow the dog proper air flow and does not restrict them for all activities; for instance, they can still drink water with the muzzle on.
Aug 16, 2012 | Pets - Others
How do i replace the lcm on my 2004 grand marquis?
The lcm is just right of the steering wheel column and left of and below the radio. you have to remove a plastic cowling under the steering column that is attached by two plastic push pins on either side of the column. there is an accessory light that needs to be unplugged from the cowling. the cowling slides out and the lcm is exposed. it's a black box a bit bigger than the size of a brick and has three wire harnesses plugged into it. the lcm is held in a metal cage bracket with two hex head screws. After removing the screws, the lcm can be pushed up slightly and out of the cage toward the front of the fire wall. it's easier to detach the harnesses after the lcm is out of the cage.
Nov 26, 2011 | 2004 Mercury Grand Marquis
Hpw do I install an ac/heat blower unit
disconnect the negative battery cable
Disconnect wiring harness and rubber tube to motor. Then remove the 3 screws and remove motor and cage
Use a vice grips to put on cage axle and remove the cage and axle and place on new motor and reinstall
Apr 08, 2010 | 1988 Volkswagen Cabriolet
I want to clean the squirl cage fan on my Carrier handler. It's 12 years old and never really been cleaned. What is the best cleaning procedure to maximize its efficiency.
The best way to really clean the squirrel cage is to remove the entire indoor blower motor housing assembly out of the furnace then remove the squirrel cage from the motor shaft and pressure wash the squirrel cage. Make sure you don't use to much water pressure as you might knock off any balancing weights that may be attached to the one or more of the vanes. Make sure the cage is completely dry before you re-install it back on the motor shaft.
Nov 16, 2009 | Kitchen Ranges
Physical installation of 2nd hdd
The document below gives instruction for installing, but the place and shape of the cabinet and hdd case may be different from you PC. You can use this as a refrence. Installing a hard disk drive Use the steps in this section to install a new hard drive into an empty drive bay. Step 1
If you are installing a new hard disk drive, make sure it is set to cable select. c01179815.jpg Step 2
Slide the hard disk drive into the hard drive cage. c01196498.jpg Step 3
Align the screw holes on the hard drive with the screw holes on the hard drive cage. c01179817.jpg NOTE: Make sure the connectors are at the top of the hard drive cage. c01179818.jpg Step 4
Replace the four screws (two on each side) to secure the hard drive to the hard drive cage. c01179813.jpg Step 5
Connect the power and data cables to the drive. The connectors are keyed and can be attached in only one way. c01179809.jpg Step 6
Insert the hard drive cage into the PC.
Align the four tabs on the side of the hard drive cage with... c01179819.jpg ... the four slots inside the PC. c01179820.jpg Align the three tabs on the side of the hard drive cage with ... c01179821.jpg ... the three slots on the front of the PC. c01179822.jpg Step 7
Slide the hard drive cage down until it snaps into place. c01196499.gif NOTE: Make sure the front tabs on the hard drive cage are correctly inserted into the slots on the front of the PC. c01196500.gif Step 8
Replace the two screws that secure the hard drive cage to the PC. c01179804.jpg Step 9
If you are adding another hard drive instead of replacing a hard drive, connect the SATA data cable for the new hard drive to the next available SATA connector on the mother board.
NOTE: The SATA data connectors on *********** board may look slightly different than the example. c01833532.gif Step 10
Replace the front panel and the side panel, and then reconnect the cables.
For more information about replacing the side panel and the front cover, refer to the HP support documents Removing the Front Cover and Opening the PC Case . c01179827.jpg Step 11
If using Windows, wait until Windows finds and configures the new drive. c00615034.gif
Regards,
Shrey
Oct 07, 2009 | Computers & Internet
Where can I obtain circuit diagrams/service manual for panasonic video recorder model NV-MV20GL?
a panasonic warranty depot.the most common problem was a broken gear that drives the rack on the loading cage.some models had plastic gears and others had metal.i used to replace the plastic ones with metal,because if a tape was inserted slightlyon an angle,the gear would break,because the release pin would not let the loading basket go down.there are timing marks on all the gears and it is very tricky to set the timing on that machine.the best way to do it is to run the unit with the loading basket out of the machine,it will load up around the video head,stop and load back and shut off. unplug the machine,backload the main gear one tooth,as it is under tension,and insert the loading cage and secure it with the two tabs on front,and the 2 screws on the back.the other problem was broken pinch roller assemblies.the gear has an arrow that lines up with the arrow on the main load gear.
Jul 13, 2009 | Panasonic Televison & Video
Schwinn 26in Women's Mirada Bicycle Logo
457 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
