Question about Tanita BF680W Duo Scale Plus Body Fat Monitor & Body Water % & Athlete Mode
I have a tanita scale item # BF680W. I need to know how to change the mode from st -lb (british measurements) to lbs. the setting on the back is correctly set. No matter what setting iit is on, it shows up st-lb. Is there a way to repair this?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 141 Answers
Set in default ya read this apratus............
Posted on Mar 20, 2011
Someone has switched my tanita BF 625 to metric readout and i don't know how to switch it back
Press the set and arrow UP button at the same time. Then use arrow UP to find lbs. Press the set button to confirm.
Jan 29, 2011 | Tanita Digital Body Fat Scale with 2...
Changed batteries and now the scale does not read correct weights. off by more than 40 lbs
You might wanna double check that your scale is set to the right measurement. On the bottom of the scale is a switch that allows you to choose between Kg (kilograms) or LB (pounds).
Jan 18, 2010 | Conair WW60 Weightwatchers Scale
The scale only measures in 'stone' weight
I contacted the manufacturer of the porduct here is what they suggested you do
Please insure that there is nothing inside that area that may be hindering the switch to change from mode to mode.
You can also remove the batteries for a period of 24 hours to see if that will trigger a reset in the unit.
If you continue to have problems we may be able to replace under warranty.
Your scale does carry a 10 year warranty but you will need to have a copy of the original itemized receipt (or order confirmation if purchased online) in order for us to process a warranty claim.
If you happen to have a copy of the original receipt or order confirmation, please contact our customer service line between 8:30 – 5:30, Monday – Friday, (Central Time) at 847-640-9241, and we can issue you a Return Merchandise Authorization for product replacement.
Sincerely,
Cheryl Morse
get-attachment.aspx?uid=1.22887842&folder=oldmail&partid=4
TANITA CORPORATION
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005
Office: 847 434 3985
Email: cmorse@tanita.com
Apr 09, 2009 | Tanita BF681 Scale Plus Body Fat Monitor
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
Jan 01, 2009 | Health & Beauty
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Tanita BF680W Duo Scale Plus Body Fat Monitor & Body Water % & Athlete Mode Logo
279 people viewed this question
Top Tanita Health & Beauty Experts
dkmun
Level 1 Expert
Tre Elkins
Ankit Chandel
Ankit Chandel
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
