Question about Casio FX-300MS Calculator
How can I get my calculator out of scientific notation mode? It is a casio fx 300ms
Please press the Mode button on your calculator repeatedly till you get the following screen
Fix Sci Norm
1 2 3
Press 3 from your keypad and the screen will change to
Norm 1~2?
Press 1 from your keypad and your calculator will be normal again i.e out of scientific notation mode.
Posted on Mar 16, 2011
How do i convert a number in scientific notation using the calculator?
You can always enter a number in scientific notation. Use the EE or the [x10^X] key to enter the exponent of 10. Whether it will remain in that form depends on the display mode you set the calculator into:SCI, ENG, NORM1, NORM2, FIX.
However if a result is too big or too small, it will always be represented in SCIentific format.
Sep 09, 2011 | Casio FX-300MS Calculator
How do you get a casio fx-300MS out of scientific notation form?
Press Mode a number of times until you see below:
Then press 3 to select Norm.
May 19, 2011 | Casio FX-300MS Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
How do i get my calculator to stop displyaing 15!/5! as 1.08972864*10*10?
You don't. The calculator can display only ten digits in a number. This number has eleven digits to the left of the decimal point, so the only way the calculator can display the most significant digits is to switch to scientific notation.
Oct 06, 2010 | Casio FX-300MS Calculator
Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
Apr 16, 2010 | Casio fx-300ES Calculator
How to change or put math mode without fractions or scientific notation on calculator fx-155 es natural display
Press SHIFT MATH 2 to switch to the LineIO mode. You won't see fractions then. However, if magnitude of the number is too large or too small, the calculator will switch to scientific notation in order to fit into the display.
Mar 22, 2010 | Casio FX-115ES Scientific Calculator
How do you enter a number in scientific notation on a casio fx-82B?
how do i get my fx-300ms calculator do to expanded notation?
Nov 10, 2009 | Casio Office Equipment & Supplies
Is there a way to fix the casio fx 260 solar to display numbers in scientific notation Like 3 x 10(raised to the 2nd power)?
This can be done by setting the calculator to the right MODE. Press MODE 9 to turn on scientific notation. For example, compute 1 / 200 = and you will see 5 with a -03 exponent in the upper right. Press MODE 9 again and it will be displayed .005
To enter numbers in scientific notation use the EXP at the bottom. To enter .005, press 5 then EXP then +/- then 3. You will see it displayed. Then you can perform calculations with this entered number.
Oct 01, 2009 | Casio FX-260 Calculator
Reset?!
Thank You so very much, this solution fixed my problem.
Jan 22, 2008 | Casio FX-300MS Calculator
Casio FX-300MS Calculator Logo
2,755 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
