Question about Australian Gold Gold And Bronze Dark Tanning Bed Lotion
I replace the bulb and it keeps blowing it out it only happens to the one bulb.
  • 3 Answers
Did you replace the starter? It's the little round thing the bulb goes into. I usually replace mine every other time I relamp my bed. I hope this helps.
Good luck & Happy tanning:)
Posted on Jun 19, 2013
I replace a bulb and it keeps blowing it out.what is the fix
Posted on Feb 09, 2012
The leftside indicator keeps blowing the bulbs
you have a short in the wireing...easiest way is to put new piece of wire from bulb holder and connect it back into the harness further into the car...........
cheers
Jan 01, 2017 | Citroen Cars & Trucks
Right hand side indicator keeps fusing
does the right hand turn signal keep blowing the fuse. if so, remove one bulb (back) and see if it still happens. if not replace the bulb and remove the other bulb (front). if it still happens it sounds like something in the signal light wiring is shorted. best place to check for shorts and easiest is the connectors itself.
Apr 10, 2016 | Cars & Trucks
Light bulb keeps blowing out on simplicity snow blower
Same thing happens to mine... voltage is spiking and blowing the bulb,also hand warmers get too hot. needs a new voltage regulator. I'm trying to get simplicity to replace under warranty since I brought it into an authorized repair place for this before the warranty was up.
Jan 29, 2015 | Simplicity L1528E 2-Stage Snowblower...
Why my isuzu d max headlight keeps blowing
check for loose bulbs and dirty earth points. Bulbs blow because of power surges normally from bad connections and loose bulbs.
Dec 23, 2014 | Isuzu Cars & Trucks
Every time I turn on the right turn signal the Fues blows. What to do? It only happens on the right turn. I keep replacing fusses , what to do?
replace the right turn signal bulbs... one of them is shorted out (filiment broke and is grounding to the body of the bulb)
Mar 23, 2013 | Cars & Trucks
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Nov 27, 2012 | MagLite Mag-Lite& Flashlight
I have a toshiba 42 in rear projection i dont know the model number as the sticker has been removed of the back but everytime i turn the tv on the bulbs glow at the bottom but do not light up and it keeps...
Sounds like the bulb for the TV has gone bad and you need to buy a new one. In the bulbs weakened state, it is not at the resistance level it should be and more current is getting to other components. That fuse is probably designed to protect the mainboard when this happens. Buy a new, not off brand bulb.
Use gloves to replace the bulb and never, ever touch the glass face. Any amount of oil will cause it to ware uneveningly and go out prematurely.
May 14, 2011 | Televison & Video
Tv keeps blowing blubs every year why
if its a plasma tv then it happens.. if a bulb in a plasma tv is displaying the same color for some while then the bulbs can overheat. for instance plasmas tvs in the airports have to be replaced after a couple of years because they are showing the same picture for a while .. which causes the bulb overheat .
Jan 26, 2011 | Televison & Video
Australian Gold Gold And Bronze Dark Tanning Bed Lotion Logo
219 people viewed this question
Top Australian Gold Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Australian Gold Health and Beauty Expert? Answer questions, earn points and help others
