Question about Eureka Vacuums
I have a eureka capture 8802. How do you remove the motor?
3 Suggested Answers
  • 112 Answers
SOURCE: my eureka capture is very noisy
Vacuums need cleaning too. Remove the hose and check for the noise it may be a partial blockage in the hose, if not replace the hepa filter. Problems with belt come with the brush not turning or a bad smell. If it is a belt problem it is usually apparent when you turn it over. You may have to remove 4 or lass screws to get to the problem.
Posted on Aug 12, 2009
  • 255 Answers
SOURCE: how do you change a motor for a eureka model 8851
All of these vacuums capture the motor assembly between two plastic case halves, or are held in place by a band. Take out the phillips screws (sometimes the screws are under decorative plugs to hide them) and carefully pull one half off. You'll have a lot of taking apart to do, but if you actually got a replacement motor, it will be worth it.
Posted on Nov 25, 2009
My Eureka capture bagless vacuum has just started making a loud siren like sound. It is deafening. what is the problem?
does it smell like burning rubber if not check beater brush it sounds like something may be jammed in it or near where it goes up past beater bar into the vacumn inlet if you do have a burning smell the motor shaft is spinning and thinning the belt and may also be making that sound as shaft spins on loose belt
Dec 26, 2009 | Eureka Capture Upright Vacuum Vacuum
How do you change a motor for a eureka model 8851
Nov 25, 2009 | Eureka Capture Upright Vacuum Vacuum
Not sucing
The reason it is not picking up is probably because the belt is stretched, worn or broken and is not turning the brush the way it should and therefore not picking anything up. You should change the belt on your model at least once a year. Here is a link to the belt you need and a link to the owners manual which has belt changing instructions:
Eureka Capture Replacement Belts
Eureka Capture Owner's Guide
Nov 08, 2009 | Eureka Capture Upright Vacuum Vacuum
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Yes, you probably need to replace the belt. Below I have listed a link to the owners manual which has instructions on how to change the belt and a link to the replacement belt you need. Hope it helps you!
Nov 01, 2009 | Eureka Capture Upright Vacuum Vacuum
My eureka capture is very noisy
check belt whistling may be something in hose
Aug 12, 2009 | Eureka 2971AV EZ Kleen Bagless Upright...
Wont turn on
usuasl the bushes have wore out on the motor .they need replaceing
May 24, 2009 | Eureka Capture Upright Vacuum Vacuum
Vacuums Logo
24 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
