The problem is my computer keeps pressing the c letter by itself even in bios
  • Dibas Man Mar 15, 2011
    its a small asus ee pc laptop already cleaned it still not workingg going crazy with this pc
    when i press it doesnt type but it keeps typing by itself
  • 917 Answers
You have a faulty keyboard. Try cleaning it. If this fails then replace it.
Posted on Mar 15, 2011
  • 1 more comment
  • Raj Patel Mar 15, 2011
    Replace the keyboard.
    the pc is brand new......i dont think i is possible to replace this laptop keyboard
    If it is under warranty then return it to where you bought it from.
Samsung NC10: Severe Fn key problem
i would check the bios for an option to keep fn always on and disable that. i would also try updating the bios. THIS HAS NOTHING TO DO WITH THE OS
Feb 26, 2014 | Samsung NC10-14GW Notebook
Forget password acer aspire 3610
Acer laptops are equipped with a BIOS utility. The BIOS (which stands for "Basic Input Output System") acts as an interface between the hardware and software installed on the computer. On some computers, a BIOS password may be required in order to boot the computer and make changes to the BIOS settings. If you are unable to access the BIOS settings and do not know how to reset the BIOS password, you might be tempted to send the computer back to the manufacturer for repair. Fortunately, that's not necessary as there is a simple way to do this on your own.
Go to "Start," then perform a search for "Command Prompt." The Windows Start button is located in the lower-left corner of your computer screen. Double-click on "Command Prompt" to open the application. You will need to use MS-DOS commands to reset the BIOS password. Type the following commands one by one in the order shown: debug o 70 2E o 71 FF quit Make sure that you are typing the letter "o" and not a zero at the beginning of the second and third commands. Reboot your computer by clicking "Start," "Shutdown," and then "Restart." The BIOS password will now be reset to default. or To get into your computer's Basic Input-Output System (BIOS), your computer must be on, but your operating system cannot be running. If the Microsoft Windows operating system has even started to load, you will not be able to access your BIOS. This is why getting into the BIOS on an Acer Aspire netbook computer must be done specifically during your computer's initial boot-up sequence, which happens immediately after pressing the power button on the device.
Turn on your Acer Aspire. Press and hold the "Ctrl" key. Press and hold the "Alt" key. Press and hold the "Esc" key. This key combination will open the BIOS on your Acer Aspire.
Feb 03, 2013 | Acer Aspire 3610 Notebook
Reset bios on acer aspire e380
You can reset BIOS setting by CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
If the computer still does not boot, then it needs repair.
Thanks and regards,
Jitha
Dec 16, 2011 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Computer is turned on, but screen is black
The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Link to latest BIOS
Sep 21, 2010 | Acer Aspire One PC Notebook
Letters keep backspacing
Try pressing the "insert" key.
May 22, 2010 | HP 386209-001 Keyboard
Is video card/motherboard dead?
Do you normally "logon" to the computer or does it load completely by itself.
If you wait for the system to "settle" you can test the computer w/o the monitor:
1. Press the "windows logo" key on the lower left of your keyboard
2. Press the letter R
3 Type WRITE
4. Type a few random letters ~ran~dom~
5. Press this three key sequence:
[Alt]F [P]
(Alt & F) together then the P key
Your random document will print if the computer is actually running.
ok, I suggest you reset your BIOS by removing the mobo battery or by shorting the "reset" pins next to the nattery or BIOS chip.
Go from there...
Sep 22, 2009 | HP Pavilion MX70 17" CRT Monitor
How can I password-protect all files on my laptop?
Hi there.
You can set a bios and hard drive password either by using Acer Empowering Technology application or entering the bios itself by restarting the computer and hit F2 while its just starting up, make sure you keep your password safe because if you forget the the passwords you may find yourself locked out of your own computer and bios passwords are very hard to crack.
Good luck and thanks for using FixYa!!
May 13, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer One pc notebook black screen?!
That is a problem of BIOS. U need to reset your BIOS.
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
May 07, 2009 | Acer Aspire One PC Notebook
MY COMPUTER WONT START UP!
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Jan 13, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
