Question about Belkin Surf Share Wireless USB Adapters (F7D2101)
Installed belkin Surf USB but it is unable to get Ip address from bt hub tried uninstalling and reinstalling no change
    President:
  • 1,623 Answers
There is a button on the bt hub with the wireless sign on it, press it to allow the usb device to connect. You onlt need to to do this once its a security measure to stop anyone logging into your wireless network. Also it will only stay allowable for connections for a short period of time. But as i have said you only need to do it once to allow the new computer to connect.
Please vote if you found this info useful
Posted on Mar 15, 2011
Phone is displaying DHCP:discovery boot ver 02.01.00.04. Mitel phone was working perfectly until router changed to BT Hub. What can I do to resolve it?
You can download the TNA analyzer to test ports. Or your router is not giving dhcp to the phone. You can try to statically assign an IP address to. The phone.
Feb 18, 2013 | Mitel 5224 IP Phone
We have a Belkin USB hub successfully networking 3 printers to two PCs. We are currently making the drastic switch to two new iMacs to replace the decrepit, outdated PCs. How can we get the printers up...
it's a wireless access point;configure your imacs pc with any pivate ip address like 192.168.1.1/192.168.1.2 etc and don't forget to installed ethernet driver and wireless daemon is on select the authenication protocols as stated in the access point;hope it connect
Dec 01, 2009 | Belkin 5-Port USB Hub
Hung on connecting to router
Reinstall the computer operating system and then install the adapter drivers.
Nov 05, 2009 | Belkin Wireless-N USB 2.0 Adapter
Belkin Wireless 5-Port Hub (F5L009) Problem
If you set the allowed IP address in the security section of the router then you must fix your computer IP to 192.168.1.101 with a subnet mask of 255.255.255.0 the default gateway should still be 192.168.1.1 and when you get in delete the security locking out all but the one address. Good Luck
Sep 03, 2009 | Belkin Wireless USB Hub
Just installed a D-Link DFE 530TX network adadpter into Dell Dimension 5000 desk top. Runnng Windows XP SP3. BT Home Hub 2.0 router. Even though broadband connection is fine to the router. The network...
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Jul 12, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
Cannot connect printer to a home network through BT Homehub 2
Probably going to have to go to Lexmark web site n download the drivers for that printer.
May 03, 2009 | Office Equipment & Supplies
Unable to connect wirelessly to my Samsung CLP 315W
configure the setting manually by putting the printers IP address....install the driver first
verify your printers support site and download the updated/new drivers and patches need to install.
link for Drivers and manual:
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=colorlaserprinters&model_nm=CLP-315W&language=&cate_type=all&dType=D&mType=SW&vType=&prd_ia_cd=06010200&disp_nm=CLP-315W&model_cd=CLP-315W/XAA&menu=download
Mar 20, 2009 | Samsung CLP 315 Laser Printer
Wont connect ti internet
Same device as mine. and im on home hub aswell. Uninstall the drivers. Restart windows. Reinstall the drivers. Hopefully this should make a differance. Also when reinstalling. make sure the device is not plugged in until you finish installing drivers. And maybe put it into another usb when you are ready to try again. this is something good to try on older systems. or OS's.
Oct 02, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Unable to access the network
There are two things you can try, one is renaming the SSID in the Wireless settings from the default (WLAN) to another name then release and re-new the IP addresses. If that does not appear to work try uninstalling the Wireless USB network adapter(s), reboot and reinstall and that should solve the problem.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Belkin Surf  Share Wireless USB Adapters (F7D2101) Logo
325 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
