Question about Garden
I have A model pp338pt poulan pole pruner trimmer with a 33cc motor on it I want a owner and parts manual for it.
  • 95 Answers
For a owners manual go to manualsonline.com.The parts list you can look up your model number at ereplacementparts.com It will show you a full list of parts. Hope this helps
Posted on Mar 17, 2011
Part of the chain came off track
if it is a pole chain saw , and the chain came off, it is installed the same as any chain saw
undo the cover over the drive end , remove the blade and chain, loosen of the screw that adjusts the blade length
put the chain back on the blade , put the blade and chain back on the machine , replace the cover and do the nut up till it just touches the cover
adjust the screw until the chain is at a position where if you pull the chain off the bar the inside guide teeth are about halfway out of the bar guide
tighten up the cover nut
Aug 13, 2016 | Poulan pro pp338pt pole pruner - trimmer...
Saw attachment will work but weed trimmer attachment will not turn
check that the trimmer attachment is fitted properly on the shaft as it appears the the shaft drive is not engaging in the head
May 23, 2015 | Poulan Pro PP338PT 8 33 cc Gas Pole Saw...
Poulan Pro Pruner cuts off when trigger is pulled past halfway; is this car orator issues?
Most likely carb adjustment. Try enrichment adjustment about 1/8 turn at a time, remembering where is was in case you need to go back.
Oct 01, 2014 | Poulan Pro Gas Pole Pruner Trimmer -...
Poulan pp338pt 33cc prnner trimmer stalls out
The black plastic piece is part of the fuel cap. Start with an initial carb adjustment of 1 full turn out on both low and high scews.
Sep 28, 2014 | Garden
Did not get an owners manual with my 33cc gastrimmer need to know the gas oil mixture .
40:1 = 3.2 oz of 2 stroke oil for every gallon of gas
Link to manual is below http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
May 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I had to replace all my gas line on my Poulan 446t i need someone that knows how they hookup
Typical fuel system and a couple of tips. Leave the carburetor connections a little long so they can be swapped if need be. I think the upper most connection goes to the bleeder.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
I think this is an IPL for your pole saw: (there are others, this may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP446T-Gas-Pole-Pruner/75.PP446T-Gas-Pole-Pruner.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
All Models:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type (true for chainsaw, my first pole saw. If uncertain try to contact them please.). HTH
Lou
Please reply back (below) with the final configuration. Help me provide better guidance to the next guy please.
Feb 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you change a poulan ploesaw pull cord
Use Clothes line rope and tie off at eye let and run rope as it was before and it will work fine. You can also make your new rope as long or short as you perfer.
Jul 29, 2009 | Poulan/Weed Eater No. 5000p 952711612 Pole...
Engine dies when blades are engaged
sounds like one of the safetey switches are not working
Mar 22, 2009 | Poulan/Weed Eater No. 5000p 952711612 Pole...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
