Question about Delta TP305 12 - 1/2" Portable Planer
Do you have a owners manual for a Delta planer tp305
  • 2,176 Answers
Go to Dewaltservicenet.com and you can download the owners manual for this tool, it is 48 pages long. Let me know if you need more help and if I have answered your question would you please vote accordingly, thanks
Posted on Mar 16, 2011
Testimonial: "Great job getting that information for me, thx"
Sniping
You get sniping with all planers and it will always be the length from the cutter head to the second feed roller. Until the board goes under the second roller it is almost impossible to feed it through and not get some sniping. The same applies to the outfeed side also. Better made (more expensive) planers, table extensions and holding up on the end of the board until the other end is under the second feed roller will reduce sniping somewhat but you'll always have some sniping.
Mar 03, 2013 | Delta TP305 12 - 1/2" Portable Planer
My tp305 removes more wood on the left than on the right. There does'nt seem to be anmy way to adjust this, is there?
These portable planers have a not-negligible amount of flex to them, and you will probably remove a bit of wood even if you run the board through a second time on the same side. But try this to determine if you would want to try to reset the blade height---- run two narrow pieces simultaneously on the left and right. Check the thickness before and after with calipers or something precise. Then switch the two boards and run them again without changing the setting. If it is only cutting on one side, and the thickness was significantly different before the second run, then you might want to adjust the blades in the cutter-head.
Good luck.
Oct 01, 2012 | Delta TP305 12 - 1/2" Portable Planer
Need to find Delta 12 1/2 " Planer Instruction Manual # TP305
Porter-Cable/Delta has the manual at their Servicenet support site: http://servicenet.deltaportercable.com/Products/Detail?productNumber=TP305 . The link is on the right under downloads (the last item in the list).
I hope this helps.
May 29, 2011 | Garden
Why do i get saw dust build up uder my blade and end up bending the blade and hold down bar
U need to hook it to a strong shop vac. There is an adapter for a vacuum hose. Joe
Mar 20, 2010 | Delta TP305 12 - 1/2" Portable Planer
How do you replace the belt?
go to Dewaltservicenet.com and type in your model number and you will find a detailed breakdown for this tool. Let me know if you need more assistance
Dec 15, 2009 | Delta TP305 12 - 1/2" Portable Planer
Need an user/owner manual for a Delta Shopmaster 12'' Portable Planer Model #TP300
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Oct 15, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Belt on delta planer
I went to Dewaltservicenet.com and looked at a parts explosion and also the instruction manual for this tool. The manual doesn't say anything about how to do it, BUT the explosion is good quality and should guide you thru replacement. Please let me know if I can help further and if I answered your question would you please rate it accordingly Thank you.
May 15, 2009 | Delta TP305 12 - 1/2" Portable Planer
How to change planer blades on the Delta PT400LS 12.5" planer?
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
Nov 19, 2008 | Delta TP300 Shopmaster 12-Inch Portable...
Delta TP305 12 - 1/2" Portable Planer Logo
284 people viewed this question
Top Delta Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Delta Craft and Hobby Expert? Answer questions, earn points and help others
