Question about HP (C7972A-10PK) LTO Ultrium Storage Media
Issues with a C7972A 400GB tape: I observed that when the backup size reaches over 250GB, the tape starts giving an error that it cannot complete the backup. Is there a limitation on how much data can be placed on these tapes?
  • 917 Answers
This tape is 200GB with no compression, up to 400GB with compression assuming 2:1 compression ratio. The compression ration is dependent on the type of file e.g. an MP3 file will not compress much, nor will a ZIP or JPG file, but BMP, DOC, TIFF will compress well. In my experience it is best to assume worst case and calculate for no compression i.e. assume max capacity of 200GB.
Posted on Mar 15, 2011
Backup tape(RDX) getting ejected automatically after sometime while backup job is not running.
RDX tape drives, by HP (tandenberg)
did you reload all that HP software and drivers fresh?
did you try fresh tape.
i replace the tape drive, (new , used, NOS , from whom, ebay)
i bet the tape drive, logs errors, if you look,
the driver software will log that, and you can see why the tape
failed, my guess, damage to the tape, end to end.
try fresh new tape, NEW in a box, not used.
Oct 13, 2017 | HP Computers & Internet
HP C7972A Ultrium Data Cartridge
With formatting software, which is usually included with the backup software.
Dec 03, 2013 | HP (C7972A-10PK) LTO Ultrium Storage Media
Dear Sir We rely on an external contractor to backup our data. We need to retrieve the data and got this reply: " [...] I have just been down to the computer room and checked. Your data backup is...
these tape cartridges are very slow to read & write. if u r reading a set of data & need to go back for certain data u have to rewind & wait & watch until that data area arrives. it takes a lot of time. in order to save time u need optical disk drives & dvds to backup your data. u can also ask them to convert your tape cartridge data into optical disks.
Sep 13, 2011 | Smead Manufacturing Company Sony AIT5 Tape...
I have a problem with my toshiba external hard drive. the problem is that when i want to delete something from hard drive or want to move to my pc it give the error 0x80070570. can you please tell me any...
More often than not this is caused by a bad sector on the hard disk, and can be fixed following these steps:
First backup the data on that hard disk to another one.
Second, click Start then click Computer.
Third, right click on the external hard drive and select Properties.
Fourth, click on the Tools tab at the top of the window that pops up and run the Error Checking software (button usually says "check now" or something similar) and follow the instructions.
This will hopefully fix any issues you have with that drive and once completed should allow you to delete and move stuff again.
Thanks, if this solution helps please rate :)
Feb 14, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
Certance Ultrium 2 tape drive
have you checked to see how much data is being backed up? Also what software are you using - it all depends on encryption
Apr 18, 2008 | Certance (CL1001-R) Ultrium Tape Drive
HP (C7972A-10PK) LTO Ultrium Storage Media Logo
105 people viewed this question
Top HP Electronics - Others Experts
Raj Patel
Vernon Taylor
Are you a HP Electronics - Other Expert? Answer questions, earn points and help others
