Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Timing gas engine john deere tractor 2010,
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 61 Answers
SOURCE: My John Deere 2010 tractors lift does not work.
Here is a link to the John Deere web site for the manuals.
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&tM=FR&searchCriteria=2010&submit=Search&language=english
Also,
The hydraulics on a 2010 are part of the transmission oil system. There is a bolt looking plug on the right side of the transmission, about half way up, about where your feet rest when your foot is not on the brake. Fill up the transmission until the oil is level with the top of the hole and is about to run out. Using HyGuard hydraulic/transmission oil or one that meets the same spec for the 2010.
Posted on Sep 10, 2009
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
John deer 4045 diesel engine timing diagram
and you can't just follow the fuel lines from pump why ??
cyl 1 is always one most forward
Dec 02, 2013 | John Deere 4020 Gas & Diesel Tractor...
Whats causes my john deer 2010 gas to run onily with choke out ? Had carb rebuilt and tank cleaned. will low compression cause this?
i have seen about 4 of these have the solenoid on the bottom of the carb stuck closed was able to clean 3 out of the 4 there not cheap so try hard to clean it also had a few briggs engines have bad safety switches shut them off so check for power and ground
Jul 08, 2012 | John Deere 2010 Tractor Basic Carburetor...
MY CARBURETOR IS WEAR DOWNWHICH I BEEN PUTTING KITS SO SHOULD I BUY A NEW CARBURETOR FOR 2010 GAS MOTOR,it,s a john-deere tractor
Yes it is time to buy a new carberator unless you know someone who can make and install bushings in the trottle plate shaft, and choke shaft. What normally happens over time is the shaft wears into the housing as it is being used which allows ecsessive air into the fuel air mixer which causes inproper run conditions and no matter how much you adjust all the settings you cannot overcome this condition so its either get new bushings made and installed or purchase a new carberator. Hope This Helps Don
Nov 28, 2009 | John Deere 2010 Tractor Basic Carburetor...
I need to know where to add hydraulic fluid in a John Deere 2010
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
Nov 04, 2009 | John Deere 4000 201000-> Gas & Diesel...
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
2010 distrubuter problems
The timing gear is made from material which will break if the gears are not meshed correctly, if the distrubiter has come loose at some time, this can chew out the timing gear and leads to all sorts of problems (ie correct timing)
Jan 26, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
462 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
