Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 wont switch on, just get loud noise of fan turning and flashing orange light on the front of system. There is a green light on inside the computer and i get 2 flashing numbers 2 + 3...Any ideas???
  • 56 Answers
Your hard drive has failed, you will need to get it replaced.
Posted on Mar 15, 2011
My dell demention 5150 has like a yellow/amber led light flashe green then goes back. wont even load on my moniter
Your system has failed to POST. It sounds like it may be the PSU. If you decide to open the computer, check if any of the capacitors are leaking or vented. Badbaps.net may be able to help you with this.
Dec 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wont switch on has power to switch dell dimension 5150
As you are syaing there is green light in on the power button on the tower. The problem could be caused with any on the internal components inside the computer. Do you see and diagnostics lights that come on in the front of the tower like 1,2,3,4. If any of those lights are on , then one of the components inside the computer is bad.
For step by step instructions on how to isolate the issue refer to the following link
http://tinyurl.com/26lbo5d
Thanks for using Fixya
Proton
Jul 23, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dimension 5150 box will not turn on! Just blinks, looks like an orange light. Monitor comes on then goes off to orange...
- disconnect the power cable of the box from the back of the tower and press and hold down the power button for 10 seconds (remaining power will be depleted).
- Now try using a different wall outlet.
- Check the diagnostic lights to see if the specific problem is identified (the computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel). Also, see "Power Problems" in your computer Owner's Manual and/or Service Manual.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1120147
Nov 03, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer wont start up!
try to replace the IDE/SATA cable connection..good luck
Jun 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
262 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
