Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer will not engage spin gear - Whirlpool Estate TAWS750PQ 27-Inch Washer
    Sergeant:
  • 170 Answers
Lid switch
Posted on Mar 15, 2011
The starter motor will not engage
Hi, Paul the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter spins but doesn turn the engine
Starter spins but won catch
http://www.apriliaforum.com/forums/showthread.php?189764-starter-spins-but-doesnt-engage
Inside look of starter spinning but not engaging
May 15, 2016 | Motorcycles
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
1999 Honda F6 C Valkyrie starter spins but won't engage
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
starter spinning not engaging flywheel Honda Tech Honda Forum Discussion
1999 GL1500 starter won engage GL1500 Information Questions goldwingdocs...
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Jun 25, 2014 | 1999 Honda F6 C Valkyrie
My LG Front Load washing machine is making a grinding noise on spin cycle I believe it is coming from the motor
Hello. The noise you are hearing on spin is a failed basket support bearing. Depending on the model, you are looking at a cost of a professional to repair it of around $400+. If you do it yourself, around $200. This is a common failure on LG washers.
Apr 28, 2014 | LG WM2487H Front Load Washer
Kenmore top load washer, model #110.27802690. Recently it would stop after rinsing and agitating and I would have to turn the dial and open and close the lid and it would finally drain and spin ... but...
It could be one of several things but if the spin cycle doesn't work then it might not know to drain - checking the agitator pawls is an easy first thing to check:
The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
To check if this is the problem, pop off the cap from the top of the agitator spindle, then use a socket on an extension to remove the bolt located underneath. You may have to hold the bottom of the agitator to keep it from spinning. If you can see where the pawl dogs should engage the outer ring gear, then try turning the center hub an see if they engage. If you can't see them yet, then the spindle will lift off and you can take the center assembly out and check the condition of the teeth on the pawls. If they are worn, they won't engage either the agitator, the spin cycle, or both.
I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
Sep 16, 2013 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool washer, model lsr7010pq1, and it won't spin on spin cycle. If I give it a spin by hand it will work. Agitation works fine, and the motor is running fine on spin. Could this be a belt...
when it gets to spin try to open and close the lid and see if it engages spin. if so the timer may not be pausing right before spin to allow the gear to drop and engage the spin cycle. it can also be a clutch or trans issue.you have to sit there through rinse and see if it pauses for a second a few seconds after it starts to drain if not it may be the timer which is common if its not pausing
Jun 06, 2011 | Washing Machines
Washer does not engage in spin cycle
could be a stuck gear box. this gear box could have a mechanical problem on the spin cycle.
it usually turns the reverse rotation if it wants to spin.
check the pulley of the gear box, rotate it in one direction for twenty revolutions. see if it agitates. then next turn it on the other direction and observe if it is binding or stuck.
if you can remove the gear box and check the mechanical gears inside, maybe you can find the problem and replace the part.
tnx 4 using fixya,
drcool
Oct 16, 2008 | Frigidaire CWS3600AS Top Load Washer
Ultimate care 2 washer not spinning - not coupler
the transmission has to complete several revolutions before it engages the "spinning gear" but once engaged it should continue to turn the clutch plate as long as it is turned the same direction.
before suspecting the transmission i would first check the plastic piece above the clutch plate.aca822b.jpg
Jul 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
305 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
