Fisher and Paykel AeroTech Double - OD302M Electric Oven Logo
Posted on Mar 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OD302 double oven is very slow to heat up to temp after a self clean and power failure. Self clean was complete and power failure happened the next day. Reset clock and both top and bottom oven take forever to come up to preset temp. Broil elements heat, just do not glow, bottom element (concealed) heats just not real fast, the fan coils don't seem to heat. Please HELP!
  • loveit996 Mar 15, 2011
    Where do I get the part and how do I install it?
    They don't carry parts for Fisher & Paykel, any other sites?
Anonymous
Level 3:
  • Master 2,382 Answers
  • Posted on Mar 15, 2011
Anonymous
Master
Level 3:
Answers
2382
Questions
0
Helped
859390
Points
7450
Hi, all you need to do is replace the thermal fuse which will solve the problem.....
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
5helpful
2answers
The panel went black- no display of clock, temp, etc. The oven doesn't heat up. the light weorks inside the oven
Hello, and sorry to read about your problem.
if you have tried to re-power the unit, and still have the same issue, you then have a general main board failure,
you may want to contact a service company. it takes experience to know which part is defective.
I tried to help you. Please help me and vote/rate my response thanks.
2answers
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
3helpful
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
3helpful
2answers
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Top Fisher and Paykel Ovens Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
David Spradling
David Spradling
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
