Question about Saws
I have a 2 in 1 job site flip power saw model 55 68946 and need to remove the threaded screw(now stripped) that adjusts blade height. any suggestions for removal and replacement of the threaded screw?
    Problem Solver:
  • 11 Answers
Go to a Napa parts store (or a similair tool store) and ask for a small "easy out". This is a tool about the size of a drill bit that is specifically used for this purpose.
Posted on Mar 16, 2011
De Walt radial arm saw old model 7740. Am trying to restore it to working condition Very difficult to change the height adjustment due to binding when trying to turn the handle on the top.
The manual for the saw is included below, To free the height it may be best to remove the saw carriage from the arm to reduce the weight.
Use WD40 or equivalent to cut the rust and a suitable grease to maintain the freedom. There is a worm screw that is below the cylinder that may need lubricating. The manual shows the assembly. I routinely apply 90 weight gear oil around the large tube where it goes into the housing,
http://vintagemachinery.org/pubs/252/1213.pdf
26351737-byjyd4kzhh1rgh2pqslbdjkq-3-0.jpeg Hope this helps?
http://vintagemachinery.org/pubs/detail.aspx?id=1213
Nov 12, 2016 | Delta Radial Arm Saw
When I lower the blade on my table it sticks and then drops?
I have an old Craftsman table saw that had this problem. I read the owners manual for your saw and it suggests cleaning and lubricating the height adjustment screw threads with grease. I found that grease is not a good option with all that sawdust blowing around so after cleaning the threads thoroughly I lubricated them with Dri-Coat. It comes in a spray can and does not attract the sawdust like grease would. This should take care of your problem. Let me know if you need a source for the Dri-Coat spray.
Nov 16, 2014 | Dewalt DW744 Factory Reconditioned Heavy...
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
How to replace main shaft bearing
Almost all of the Skil table saws are the same setup when it comes to the motor and drive assembly. Remove your blade before servicing. You will need an arbor press, bearing seperator/puller and drill/driver bits (torx or philip depending on model) plus some adjustable ring pliers to accomplish this repair.
First thing you have to do is remove the motor from the saw. Place the saw on its wide side and adjust the motor with the height adjustment wheel so as to access the hex screws holding the motor to the rack.
Next, before removing the motor you need to remove the motor cord from the switch. Flip the table saw upside down flat on its table. Remove the switch cover and disconnect the black and white wire from the switch marking their position or noting the other wires from the cords position and the relation to the motor wires. Now you can undo the hex screws to release the motor.
Once your motor is released you can remove the spindle shaft by removing the 3 screws from the bearing housing. You can pry the assembly off with a couple of screwdrivers or by using a soft hammer and tapping the edges to remove.
Once removed you will have to remove the gear before you can get to the bearing. Use a bearing seperator/puller to pull the gear off the shaft. Once the gear is off you need to remove the woodruff key before removing the bearing. After the woodruff key is out you can remove the c-clip that holds the bearing to the shaft. Now you can use an arbor press to press the shaft out of the bearing.
Replace your bearing and put it back together. Any questions please post back.
Oct 12, 2009 | Skil Saws
Have a model 31-250 drum sander hard to adjust height of table
Here's a link to the online parts diagram and list, and here's an online manual you can download.
Check the lock nut adjustment on the elevating mechanism; you may have it too tight. Have you tried cleaning and oiling (use 30wt) the elevating screws? If that's all ok you'll have to realign the elevating screw bushings.
Check and adjust the table support plate adjustments to level the table.
As far as I know, there are only replacement parts available, but careful adjustment could do wonders for an older machine...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | Saws
Need to change the blade on a plasplugs diamond wheel wet saw
The shaft threads seemed to be stripped and you may have to get a set of Torx bits or if not then one bit for the torx screws to take them off. If the threads are stripped on the shaft then you may have to replace it.
Ken S.
Mar 23, 2009 | Saws
Change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Jan 18, 2009 | Saws
Dewalt 10 inch portable table saw blade height adjustment very st
What I would do is clean area with air (wear safety glasses) then I use a spray type of dry lubricant on the threads and also the plates that the motor slides on. You can also use WD-40 in a pinch. Hope this helps
Dec 07, 2008 | Dewalt Portable Table Saw Out Feed and...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
