Question about Tools & Hardware - Others
I'm looking for a "coupler"
  • 2,176 Answers
Go to "dremel.com" and you can find the part number, they also have a toll free number for technical assistance 1-800-437-3635. I would recommend calling the number, I checked the 300 series they have and don't see the coupler there. I know what part you are talking about but can't find it. Let me know if you need more assistance and if I have helped you would you please vote accordingly, thanks
Posted on Mar 16, 2011
On the 395 Dremel, where can I buy a coupler?
HOME DEPOT OR ONLINE AT DREMEL.COM
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Dremel Variable - Speed Multipro Rotary...
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
I need part # 2615294309 coupler for a 395 Dremel tool
I had the same problem - couldn't get the part (plastic coupler between the spline drive shafts). I purchased a waterproof **** Splice (GB-AMT-5126 12-10 gauge -- used for electrical wire splicing -- got it at Home Depot). Clipped off about 3/8" on each end with diagonal cutters and attached it to the shafts. The steel ring in the middle of the **** Splice connector provides good structural support to the connection. Works like a charm. Plus with a pack of 4 connectors, I have 3 in reserve.
May 24, 2010 | Dremel Variable - Speed Multipro Rotary...
Stripped plastic coupler on output shaft of Dremel model 277
I'm guessing, but I think that the Sears tool uses the same flexible coupling. If you go to www.searspartsdirect.com and put in the model 572610031, you can look at the diagram and decide for yourself. I think the part costs $2.57. If it's the right one, I'd order two or three for the future.
Hope this helps.
Oct 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Nylon Coupler cracks when installing
I would call Dremel direct at 1-800-437-3635 and order them. They also have a tech line, but I would think that they are in a bind when installing and cracking. Look at the bearings to make sure they are not tight or completely locked up. Let me know if I can help further
Dec 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Nylon Coupler crscks when installing
I'll answer last question first. They might be cracking because they are in a bind and when turned on or inserted on the shaft there is too much pressure. Make sure the shafts are free of any debris from the original coupling, also check the bearings for wear or being so tight that they twist the coupling. Everything should move freely. And second I would recommend calling Dremel direct at 1-800-437-3635 for replacement parts. Hope this helps.
Dave
Dremel 395 Type 2
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988!
The part number for the Nylon Coupler is:
Illustration Code Number: 5
Description: Flex Coupling
Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
Jun 15, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
