Question about Garden
Husqvarna 2348 riding mower will not pump fuel to carb.
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
mowerman1857
  • 389 Answers
SOURCE: How do you remove the electric clutch from a
Remove the primary belt and mowing deck to give yourself some room to work.
Locate the wires from the clutch and follow them toward the frame until you find the plug and unplug it.
Remove the bolt and washer from the center of the clutch going up into the engine crankshaft and slide it off the shaft. It is quite heavy so be careful when it comes free.
Posted on Sep 23, 2009
ozark333
  • 396 Answers
SOURCE: I have a Craftsman mower LT1000 riding mower 17
Also, unplug the wires connected to the bottom of the float-bowl. Just wiggle the plug loose off the bottom of the bowl.
These are 12 volt powered when the ignition is on. Put your key in the ignition and turn it to ON. * DO NOT ATTEMPT TO START THE MOWER.*
With the key in the ON position, use a volt meter and test for 12 Volts
to the terminals of the plug. The Grey is Positive and the Black is Ground.
You should see 12 volts to this connection which powers the Fuel Shut-off solenoid. This solenoid shuts off fuel when you turn off your mower to prevent backfires (IMO-doesnt work!) If you dont see 12 volts, check the plug on the opposite side of your mower where the Grey and Black wires go to. We have had several of these connections fail due to corrosion (needs di-electric grease-Craftsman...are you listening?) Disconnect the plug and see which pins feed the Grey wire. Now test for 12 volts at the plug on the side that leads back up to the ignition switch. If you see 12 volts you know you have the same corrosion problem. Clean the pins, if you have it, a shot of di-electric grease so it wont happen again and reconnect. Test at the float-bowl connector now. Hopefully you will see 12 volts and are all set. If no voltage is at the ignition switch side of the connector you need to test the ignition switch. I believe most mowers will use a Red wire down to the connection we checked and follow that wire to the ignition switch. Tap the wire close to the switch and test for voltage. If you have voltage you know there is a break in the wire leading to the connector. If no voltage is present at the output of the ignition switch it may be time for a new one. You could test all the wires of the ignition switch for another wire that has 12 volts when the ignition is on and simply place a jumper between that wire and the Red feed wire for the solenoid. Of course this is a last resort but should work in a pinch. Good luck.
Posted on Sep 29, 2009
brado83
  • 106 Answers
SOURCE: belt replacement on a husqvarna yth 2348 mower
do you need to know the belt configuration for this mower ive attached a user manual that shows the configuration and all adjustments on the deck and belt...
http://72.3.225.179/manuals/YTH2348-ow-e-96045000502-420798_r0.pdf
Hope this helps
Kind Regards
Brad
Posted on Jan 02, 2010
Husqvarna yth 2348 riding mower bogging down on start
dirty air fuel filter spark plug, carburetor.
Jul 14, 2016 | Husqvarna Garden
Show me how to start a Husqvarna yth 2348 riding more
A copy of the manual is available here: http://www.manualslib.com/download/502577/Husqvarna-Yth2348.html
Apr 01, 2015 | Husqvarna Garden
How to start a Husqvarna yth 2348
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
If this is a briggs and stratton they have a fuel pump on the front of the carb and ethanol plays havoc with the diaphrams in the fuel pump. I have to overhaul the fuel pump each year. Before you try anything else try "mechanic in a bottle" first. It is available at home depot, lowes, tractor supply etc. Just follow directions on the bottle and often it will clean out the varnish deposits in the pump and the carb both. Hope that helps.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My 25 horse kohler starts when I put gas in the carb, then shuts off. I have gas from the fuel pump--HELP!
first check for power going to the solenoid on the bottom of the carb its a anti backfire valve if you have power there when the key is cranking and when turned on the solenoid might just be stuck if that works maybe the gas that was left in the carb turn bad
Apr 10, 2012 | Husqvarna Garden
Husq 2348 riding mower blades engage, run for maybe 5 minutes, then disengage on their own
Sounds like your PTO switch or clutch has gone bad. Unfortunately, it is usually the clutch.
Sep 19, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Belt replacement on a husqvarna yth 2348 mower
Hope this helps
Kind Regards
Brad
Dec 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
