Question about Konica Minolta DiMAGE G500 Digital Camera
"CARD IS PROTECTED"
How do I erase the "CARD IS PROTECTED" I tried the procedure listed in the operators manual without success.
  • 659 Answers
Are the images locked? on internal memory? or is it on a sd card?
(SD and MS cards feature a write lock. Unlock the card.)
also
This maybe useful to anyone whose "lock" toggle has fallen off. The plastic toggle is there to activate a switch in the device (like in digital camera) not on the card. To get the device to see the card as unlocked, just glue a small piece of plastic to fill the slot in the side of the SD card casing. You will loose the SD card lock feature but at least you will be able to write data to the card again Also, if you don't feel like glueing just stick a piece of tape on the side that will work too
Posted on Aug 01, 2008
How can i format write protected micro sd card 32gb....
Slide the write protect tab forward to remove the write protection. You cannot format it while it is write protected. Formatting will erase all data on the card. Install the card into a Windows or MAC and wait for the device to detect and mount the card. Use the appropriate procedure for the machine to format the card. See this procedure for additional step-by-step operations after the write protect tab has been moved.
How to Format an SD Card
Oct 22, 2015 | Electronics - Others
Hi, i plugged in my SD card on the tv and it played perfectly. Now i wanted to download the photos on my computer but it says its corrupted. BTW i have Panasonic SD HC 16 GB
There must be some eject/remove procedure on the tv that you didn't use....you probably just pulled out the card. The problem is by not using the procedure, the tv was still accessing the data on the card. Pulling it out corrupted it. You may be able to get the pics off of it by using a picture kiosk machine at your nearest Walmart store. If successful, you can get your card working again by formatting it in the camera to completely erase it and optimize it for the camera's operating system.
Sep 06, 2011 | Cameras
I have the Nikon D5000. I have one picture on my memory card that has somehow become locked. Therefore, I have to manually delete ALL my pictures. How do I delete this one picture that is locked/write...
Take the memory card out insert it into a card reader and connect to a system. After you have backed up all the data without opening the files on the mem. card right click on the card icon and select format . Choose full format option. This would erase all the files.
Regards.
Jul 15, 2011 | Nikon Coolpix 4500 Digital Camera
My card says it is write protected for no seeming reason and is not letting me erase my pics from it.
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 04, 2011 | Cameras
My start up wont start the computer i keep getting a blue screen
have you tried booting in safe mode?if not try it first.
if you have successfully loged in safe mode. Try using the system restore to restore the system.
if you still have blue screens. do the following.
first try removing the video card and the memory card.
Clean the gold bars using a white eraser.
after cleaning put them back and make sure they are properly inserted in their slots.
Turn on the computer, if the problem still occurs try removing your cd rom drive.
Turn on the computer if the problem still occurs that means your operating system is corrupted or you have a broken harddisk.
Try reinstalling a new operating system. If you have so many important datas in your hard drive I suggest you use Windows 7 cause you can install without reformatting your hard drive.
Here is a video tutorial on how to install windows 7 without restarting.
If a problem occurs during installation it means you have a broken hard drive you have to replace it.
Goodluck, please give me updates if you have any success. THANKS.
Jun 29, 2011 | Dell Dimension E521 (D10E16) PC Desktop
What is the meaning of card is protected?
Than means you can't erase the data on that card without a password, or administative controls. Someone somehow had requested to make this card protected.
Dec 14, 2010 | Fuji FinePix S1000FD Digital Camera
Erased pictures.
You can try connecting the memory card to a PC via a memory card reader and using an undelete utility to recover the files. Go to this link for a step-by-step procedure and software references (free). http://www.ehow.com/how_4461259_restore-deleted-files-sd-card.html
Feb 01, 2010 | Canon PowerShot S51S Digital Camera
Protected card on my camera
Check your owners manual about protected photos. There is a setting in the camera's setup that keeps you from accidentally erasing photos.
Apr 30, 2009 | Fuji FinePix S1000FD Digital Camera
My Camrea tells me that the card is protected
Before inserting your SD memory card, slide the write-switch to unlock position. Insert the SD card, go to ‘setup menu’, then ‘format’ , format the SD card. All pictures will be erased. Refer your manual on page 87.
Apr 06, 2009 | Fuji Finepix Z20fd Digital Camera
Protected feature
There are 2 probable solutions. 1. The images are "protected" by the camera & will show "locked" when you try to erase them. 2. The SD card in the camera is locked. The solution to 1 is to unlock the images in the playback menu. See page 46 of the manual. Note that you need to select "unlock" you can't select protect as they are already protected! Solution 2 is to remove the card from the camera & check the "lock" slider that you can see on the side (although no all cards have this). Set the lock off. You can download the manual from the first link on the following page: http://www.vivitar.com/manuals/english/ViviCam6300/CameraManual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 11, 2007 | Vivitar ViviCam 6330s Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
121 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
