Question about Acer Aspire 6530-5143 Notebook PC
Acer 6530 has problem with power connector on the laptop, the cord and power supply work fine. the connector is loose and is not working, how do i replce it?
    New Friend:
You should not post replies to questions you do not know the answer to. This laptop has the power jack separate from the motherboard and just plugs into the board. No soldering necessary. The hardest part is taking the system apart and putting it back together. Search Ebay and google for the part you need and order it with the cable.
Posted on Apr 01, 2013
    Novelist:
  • 184 Answers
Here below is a laptop dc jack repair guide, hope it would help.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
But this instructions is only for people experienced with soldering and repairing computers. If you don't feel comfortable doing this job, please do not open the laptop or you can permanently damage your computer. Take your laptop to a professional repair shop instead.
Posted on Mar 16, 2011
    Sergeant:
  • 186 Answers
It's called a the DC Jack, and you would have to take the laptop completely apart so you can get to the motherboard then De solder the old jack from the motherboard then solder the new jack on the motherboard. Finally you will have to re-assemble the laptop. If you are not comfortable doing this than I suggest you take it to a local repair shop for repairs.
Posted on Mar 15, 2011
How can I repair my Acer 6530 power inlet?
Acer parts are readily available. Any computer repair shop can help you out. If it is still under warranty, contact Acer.
Dec 04, 2017 | Acer Aspire 6530-5143 Notebook PC
My acer aspire 6530 suddenly stopped charging the battery, it works with battery, works with battery and main power supply (yet, as long as the battery is still charged), and it certainly doesn't work with...
Seems like this is the case of a bad power supply adapter, and needs to be replaced. But to make sure we are on the right track, you mention towards the last statement, you said that when your laptop is off, and the battery is installed on, and without the power supply, the computer power button would flash and no sign of life right? Well take these step to see if it is the power supply, 1, check to see if the small green light is lighting from the powersupply adapter. If it is not, then 100% you have a bad power supply. 2, does the laptop power on when using the power adapter only, and with the battery pulled out? If not, then 85% still is your power supply and the other 15% is your power jack, either is loose, or bent, as we tend to plug in and out alot. 3, Does the laptop power on with the battery itself without the power supply adapter? If it does, it is not your battery. The reason to the laptop power light blinking with the battery installed only could be that the battery is low/drain and does not have issufiect charge to power up your laptop. And to say that when your system is on and your plug in the powersupply, and the small battery icon says it's charging but actually it is not. It could still be your powersupply, it is damaged but a smart chip installed on your powersupply only sending signal to your laptop, this chip is only to prevent the battery from over charging. So if you have another power supply, you cna test this out. But at this point, they was you described things, I believe it to be the power supply. I hope this help, if you have any question, let me know.
Jan 17, 2011 | Acer Aspire 6530-5143 Notebook PC
I have to wiggle power cord for it to connect for the battery to charge , i ordered a new cord and it does not fit tight nor does the orginial anymore,could there be a problem with connector from the pc
The connector on the motherboard needs to be resoldered. This is a common problem that has to be fixed right away. The loose connection will arc inside the unit and eventually damage the motherboard. Unfortunatly the entire laptop has to be disassembled as the motherboard needs to be removed . The connector needs to be removed from the board and reinstalled.
Nov 12, 2009 | Acer (56.04145.901) (5604145901) Power...
I have acer 6530 G and installed xp in place of vista..now many hardware dosnt work..wireless, fingerprint bluetooth and i dont have any of acer software on it ( acer empower etc) so how i can make use of...
Try to contact your dealer about your problem. Second, if you can access through the internet using another computer to download drivers from or the ACER SOFTWARE for your acer 6530 G so that it will solve the problem. Though you have shifted OS from Vista to Xp as long as you have drivers for your Pc it will certainly work fine.
Jun 21, 2009 | Acer Aspire 6530-5143 Notebook PC
Dell inspiron 5150 do not come on when the power button pressed
If you remove the battery and disconnect power cord, then hold power button for 20 seconds, then reconnect power cord but do not re-insert battery, and the unit powers on okay, the problem may be your battery. If there is still an intermittent problem, the power connector inside the unit may be loose and need re-soldering, or you could have a bad power supply.
May 17, 2009 | Dell Inspiron 5150 Notebook
Acer Aspire 5050 power cord not working
the connector inside the computer is broken .. I just fixed and acer the other day that had the same problem. I pugged a toshiba pwr chord into the acer that I knew worked and the connector was the same and no lights came so I knew it was something to do with the computer .. I suggest you try the same thing and if it is the connector inside the computer you should not pay over a hundered dollers to have it replaces Good Luck
May 03, 2009 | Acer Aspire 5050 Notebook
Low battery warning turned into laptop not turning on at all.
i have that problem as well ill have power one minute the charge light comes on then if i move my laptop pooof its gone i think its internal maybe a loose salder leading to the power supply. so try ro check it out u might have to take it apart to check it but no u dont need a new laptop..
dragonslair2@hotmail.com
Apr 19, 2009 | Acer Aspire One PC Notebook
Screen went black; power cord is working but won't power computer
the power plug on the laptop may be loose or broken
Mar 03, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 6530-5143 Notebook PC Logo
473 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
