Question about Tools & Hardware - Others
When i put new gas in it leaks at the top of the can is that normal ??
  • 2,176 Answers
No this is not normal, you didn't specify what tool brand you have but on the Paslode fuel cells you would need to make sure that you "click" the valve securely on top of the cell. They don't lock them in when they package them. Let me know if you need more assistance.
Posted on Mar 16, 2011
Testimonial: "yes thanks is all normal now cheers"
Leaking gas at carb bowl. On John Deere 14sb
put the flat side on the bowl edge if the new one has a flat side
otherwise it could be that the flat edge of the bowl has flattened otf the "O" ring
Could probably use an "O" ring but don't over tighten the bowl retainer nut
gaskets are normally fiber washer carby gaskets available in a variety of sizes from an auto parts store or mower shops
Mar 31, 2016 | GASKET Garden
Longjia 125cc raptor had problems with fuel leaking from the bottom of the carb and though the air filter. Just put a new carb on OK for a few day now doing the same any clues please
New carbs aren't known for leaking unless you had it open and altered some thing. A float can get stuck if you let it sit without using it. Should put stable in your tank and run it so thestable gets into the carbs.
Check above the carb for a gas leak from the gas hoses and check the gas tank. They may be running down onto the carb and just appears like the carbs leaking
Mar 07, 2016 | Motorcycles
Why is gas leaking out my Evap fresh air hose every time i try to put gas in my car and start it
I suspect you are OVERFILLING your tank...
There should be a direct connection from your canister to the top of the fill tube. It is intended to safely draw out gas fumes.
even if you don't OVERFILL... gasoline can expand (coming from the cold ground... into a nice warm car) enough to repeat the symptoms you have depicted.
Try putting in less gas...
Things will most probably resolve themselves... otherwise you might need a new canister.
Be safe... DO NOT OVERFILL.
Jan 03, 2016 | 1999 Pontiac Grand Am GT
Low idle
Remove all the injectors & put on new "O"Rings
No-- they shouldn't leak no matter what you do
Put some oil on the new ones
Mar 30, 2014 | 1993 Honda Civic 4 Door
96 honda shadow VT1100C fuel leak
if you always put as much gas as you can especially when its cheaper you are probably getting fuel into the fume emissions part of the entire fuel system. see if you can find a diagram of your fuel tank system to be sure its vacuum and not fuel. don't top off . its the worst thing to a fuel system
Feb 21, 2014 | Cars & Trucks
Po422 trouble code for 2001 dodge ram
There is a leak some where , check the lines where they have rubber on them check for cracks, the dodge is known for broken rubber boots on the end off plastic lines going to purge valve, the other problem is the top of the tank, the ring that holds pump unit in tank may have a leak.
The best way is to smoke test the system for leaks. and last is the filler neck rusts out and may have small hole
Oct 06, 2012 | 2001 Dodge Ram 1500 Truck 2WD
There is condensation around the exhaust pipe is this a problem plus the gas cap light comes on
Condensation on exhaust pipe is normal.
Gas cap light:..This may be caused by loose or leaking hoses, loose or broken fuel cap, a leak at the top of the fuel filler pipe neck, ect......
Aug 22, 2011 | 2001 Ford Mustang
My 2002 toyota sienna has evap system malfunction p0440, p0446 changed the canister closed valve vsv, check engine light came back yesterday trying to avoid replacing vapor canister which is costly but do...
You are on the right track, you replaced the vent valve and replaced the vsv valve in the engine compartment that should of solved the problem as long as the correct valves were replaced, i would check for a leak in a hose for the evap system, a smoke test would be a good way, the canister may not be the problem but the valves on the canister, there are a few vsv valves on the canister and also the pressure sensor, the switching valve is very common also, there are so many valves thats why the dealer replacing the canister as an asm, hope this helps also make sure gas cap is good.
Jan 07, 2011 | 2002 Toyota Sienna
98 beetle 2.0 gas over heated
Put good radiator an a new thermostat .Iet it warm up to normal temp .make sure the fans run an check hoses and engine block for leaks.It should be fine. The thermostat most have got stuck.
Jan 12, 2009 | 1999 Volkswagen Beetle
Tools & Hardware - Others Logo
106 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
