Question about Panasonic KX-TA824PK Phone
I have a panasonic kx ta824 system with caller id. Caller id works fine on lines 2 & 3, but no longer works on line 1. This is a new problem after 3 years of it working properly. I checked the programming and all is ok. Is it time for a new card? Thanks Bill Lucia
  • Panasonic Master
  • 2,460 Answers
Hard to say. So, go to the cabinet and swap the connections between line 1 and line 2. If the CID still comes in on line 2 and not 1, then it's hardware or programming. If it doesn't come in on 2, then it's a telco issue. Since you checked programming, it would only leave hardware. The 82493 card plugs into a slot on the main board.
Carl
Posted on Mar 16, 2011
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
I suddenly have no Caller ID name, number and announcement. I have tried the manual that came with the phone. model KX-TG7624SK 6.0 Bluetooth Talking Caller ID Panasonic. I am tired of answering "cour
Ann also check with your telephone line provider for the land line calls that the subscribed service has been activated that forwards the calling line identity to your land phone line. Could be it somehow has become lost accidentally by the phone company.
It would be worth them checking it has not fallen off your subscriber settings to eliminate it as a possible cause)
Talking Caller ID Handset Dial #162 1 on 0 is off
Base Unit caller id Dial #*162 1 on 0 is off
Guess this toggles it from 1 or 0 in the settings
Jan 27, 2015 | Panasonic KX-TG7624SK DECT 6.0 Cordless...
The caller id is working but how to look back the last caller id number(or caller id log) on the KX-T7731, i am using it with the KX-TA824 system.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
Carl
Sep 08, 2011 | Panasonic KX-T7731 Corded Phone
Hello friends from FIXYA, I have a situation where I cannot get my Panasonic KX-TA824 pbx to answer incoming call at the fist ring using DISA. I have tried everything and I cannot get it to work. DISA...
And??? What's the problem? My DISA is set for 1s on the first page and it never rings a phone. If you want it to answer the outside line on the first ring, you'll have to turn OFF Caller-ID. Now it will answer right after the first ring, but you lose CID logging.
On my working system, the DISA 6.1 section is with AA and 1 second, and 6.2 the first two timers are 3 and 5 seconds. In 9.1 you can uncheck CID but I don't recommend it.
Carl
Sep 22, 2010 | Panasonic KX-TA824PK Phone
KX TG1061 panasonic phone called id not working in India
Try connecting your phone to some other phone lines in which the caller id is working properly and this way you can check if the problem is with your device or line.
For all the phones to display the caller information properly, CLID (caller line identification service) should be enabled for your landline connection. Please contact your phone line provider to enable this service and you should be able to see the caller id information in your panasonic device.
I hope this is helpful to you
thanks
Please rate the solution
Sep 18, 2010 | Panasonic KX-TG1033S Cordless Phone
Caller Id not working KX-TG6323PK
Don't mind. Returned the product to the seller. Thanks.
Jan 11, 2009 | Panasonic KX-TG6323 1.9 GHz Trio 1-Line...
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Feb 08, 2008 | Panasonic KX-TG6702B Twin Cordless Phone
No caller ID displayed
If your cable service is transmitting the caller id data, and the phone has that feature and is working properly, you should be getting the caller id after the second ring. The only way to confirm where your problem lies (the phone or the cable service) is to take your phone to a regular phone line with caller id and see if it works, and vise versa. My guess would be that the Panasonic phone is working fine on a regular phone line of which it was designed to do, and the problem is in the cable carrier not conforming to industry standards. But I may be wrong.
Dec 29, 2007 | Panasonic KX-TG5632 Phone
Panasonic KX-TA824PK Phone Logo
182 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
