Question about Kenmore Washing Machines
I want to remove the front of the kenmore washer to get to the drain it is a kenwood super capacity stackable called the Laundry center 27" wide how do I do that
  • 4 more comments
  • tmwtiana Mar 15, 2011
    the model number is 41797962703
    the model number isfor my kenwood washing machine stackable 27" wide laundry center is 417979627035/09
    I had a sears serviceman come out and he did remove the front of the cabinet so perhaps I am giving you the wrong model number. the owners manuel that came with it has three different model numbers they are 97912 , 97962,97972
    thank you!!!! I will come back with more questions if i can't figure the rest of my problem out!!
  • tmwtiana Mar 16, 2011
    my problem was solved by the emissionwiz I was so excited to have fixed my washing machine that I must have responded improperly!!! Thank You Problem solved!!!!!
  • tmwtiana Mar 17, 2011
    it was a great help had my washing machine up and running Thank you so much emissionwiz!!
    Top Expert:
  • Kenmore Master
  • 79,865 Answers
Hello
Since Kenmore doesn't make its own washer I'll need the full model number of the machine to help you, it may not have a filter, it depends on the washer, front loaders do, top loaders don't in most models. The model will be on the back of the machine on a tag or of course with the owners manual.
Posted on Mar 15, 2011
  • 2 more comments
  • yadayada
    yadayada Mar 15, 2011
    This washer doesn't use a drain filter. The front panel is not removable, you must turn the washer over on it side and remove the bottom cover or rear cover.
  • yadayada
    Do you have 2 screws in the bottom of the front panel ? if so remove them and pull down on the panel, it should release.
  • yadayada
    Go to the link below for picture and instructions, click the page to enlarge it.
    http://media.fotki.com/1_p,ssggdsqrqqkds...
  • yadayada
    yadayada Mar 16, 2011
    If I solved your problem please reward my solution by rating it as "HELPFUL" for Fixya or I get no credit for my effort. If you lock below the problem when you open the page you will see the different ratings, Thanks
  • Kenmore Master
  • 8,220 Answers
I have a nice pictoral HERE
Service manual included.
Posted on Mar 16, 2011
  • Dan Webster
    Dan Webster Mar 16, 2011
    Remove 2 screws at the base and push down on the front panel
    The manila envelope is the tech info.
  • Dan Webster
    The pump is an electric one. It is easy to disassemble. I have found shoestrings and small items of clothing in those pumps.
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
KENMORE SUPER CAPACITY 3.5 WASHER WILL NOT DRAIN WATER OUT OF THE WASHER?
drain pump is bad or has a blockage will need to inspect drain pump and clear any blockage if clear replace pump
Jan 16, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
We have a Kenmore 3.5 Super Capacity Quiet Tumble Action Wash Easy Access. The spin cycle works however the water won't drain and our laundry is soaked. Help...
It could be either the pump or a clog in the discharge hose. Take a shop vac and attach it to the discharge hose to remove the water from the machine. Remove the pump housing and run a wire down the discharge hose to check for a clog. If there is no obstructions, reattach the pump housing and remove the pump motor. Run a spin cycle and see if the pump motor turns.
Aug 27, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 94802 - Goes through all cycles.. Doesn't stop after last spin cycle.
I hate to say it, but it sure sounds like a timer problem. There are contacts inside that move and switch items no matter what setting its in. Its a possibilty that the power contact is stuck closed and when you manually turn it off it breaks contact. The job to replace is really not that hard, remove console (unplug unit first), mark your wires, then just replace. The part though is a touch expensive (131789200 Sears Part Number). Probably would be a little cheaper than buying a new unit I guess. Let me know if you need any further information. Jim
Nov 04, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Washing Machines Logo
121 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
