Question about Lexmark X4270 All-In-One InkJet Printer
My lexmark X4270 stopped feeding when making copies or scanning.
  • 122 Answers
All you have to do is to open where you put ink and look into it to see if anything is there. If not then take out the catridge and clean it and roll those mechanism and insat the catradge or ink back and try printing again.
Posted on Mar 15, 2011
How do I scan a document on Lexmark x4270?
Perhaps the Lexmark X4270 user's guide will be able to help you. You can view and print your printer's user guide from the Lexmark website for free. Click on this link Lexmark X4200 Series User's Guide. Scroll to Scanning for the steps on how to scan a document. Make sure the Lexmark OCR scan software is installed on your computer. I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark X4270 All-In-One InkJet Printer
There are black vertical lines going down the middle of the page whne i copy or scan and fax documents. What is the problem.
It could be due to some dirt on the scan lens on the printer. Refer to this article on How to Clean the Scan Lens and White Roller on the Lexmark X4250/ X4270/ F4270. I hope this helps.
If you need additional assistance. please contact Lexmark technical support so they can help you. thanks.
Nov 04, 2010 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK X4270 SCAN ONE PAGE NOT MULTI-PAGES
S:
Please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Also, let me know the error message while scanning the document.
Apr 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 fax machine receives faxes but won't feed paper
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
Open the control panel.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Next, try to make a standalone copy and let us know the results.
Apr 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X4270) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 doesn't want to scan
sounds like your scan settings need a look..do you have the print manager installed?
May 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 won't install
if possible try a different wire or usb port
check if there is a usb conflict
just some thoughts,
good luck
Nov 12, 2007 | Lexmark X4270 All-In-One InkJet Printer
X4270 Printer
i had the same porblem and the nice people at lexmark told me how to fix it. First unplug your printer. second.. hold the stop/cancel button while you plug your printer back up..keep holding the stop/cancel button and you will see a message that says erasing memory. the fax, copy and scan lights should flash and only the fax light will be on. That should do it but you will have to put your personal information back in, like your speed dial numbers, etc.
Sep 18, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
127 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
