Question about Garden
The chain saw wont turn over i changed oil, put new gas in it, clend the carb , and checked the spark plug. What shouuld i do?
  • 784 Answers
Wath model saw u hawe?
Posted on Mar 15, 2011
I have Poulan 2375 wild thing thing chain saw I replaced plug coil carb fuel lines filters checked spark put gas in cylinder. No luck
As you have done most things regarding fuel system i would have to assume it either has not enough compression, or the ignition timing is out, so remove the muffler and check the condition of the piston face through the open port, any signs of scuffing or marking on the piston then the saw has seized at some time and the piston ring is stuck in, if all appears ok then remove the flywheel and check the key has not sheared, the key is alloy and is part of the flywheel..
Apr 21, 2018 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
My Honda 250 EX ATV keeps on stalling when ever i shift up gears
Hey,, take this to a QUALIFIED PROFESSIONAL and have them c l e a n and set the carburetor,,,,,
Sep 28, 2017 | ATVs
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Saw has lost power. Consumes a lot of fuel. Runs good from half full to empty but it surges during this time. I checked and cleaned all around the and drive, the air filter, and checked the spark plug....
There are very few things that will increase fuel consumption, blocked spark arrestor in the muffler ( metal gauze in the exhaust out let ) blocked air filter, part blocked exhaust port ( remove the muffler and check ) if the fuel tank is seperated from the chain oil tank with a gasket you may have a leakage between the two ( is the chain oil getting thinner and smell of fuel, other problems may be in the carb, leaking inlet needle, this will require a carb pressure test to prove, if you have a small bulb pressure tester, remove the fuel hose from the carb and connect the tester, put approx 2 psi in, the carb should hold this with no pressure loss.
Feb 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Will not start
remove plug dip in gasoline and try to start there could be something inside the engine restricting fuel may need to look inside motor
May 28, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
ES335 wont start, fuse checked and oil present The black hand guard is upright I have tried to move it to check that it is in the correct position but no luck, I don't want to force it . The chain saw has...
I didn't know that chain saws had fuses? The black handle you are talking about is a chain break, push it forward allows the chain to drive, if chain break is back chain will not run around the bar, safety for saw kick backs.
If it will not start:
Check and see if it has fuel.
Is the switch in the on Position?
Do you have a fowl plug? is there spark?
Is the plug wire attached correctly?
Do you have fuel going to the carb?
Is your air cleaner, clean?
DO you smell gas, if so you have probably flooded it and now you will have to remove the spark plug and get rid of excess fuel or try starting the saw with the choke on.
Aug 13, 2009 | Garden
Saw was running and quit checked gas and oil both are full
Check to see if you are getting spark. If you are getting spark then it is not getting fuel. Try sparying starter fliud in the carb. If is starts then stops. Take the fuel line off to see if something is obstructing the line. Also the fuel filter can be changed.
If you are not getting spark with the spark plu relace the plug. Also to check the spark, remove the plug and put a screw driver in the plug wire and ground the screwdriver. a spark should come off the screwdriver
May 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
