Question about Samsung N150 (36725723009) Netbook
I have just removed the back to reveal the memory on my samsung n150 plus to see if it was a ddr2 or ddr3. i removed the battery and now when i try and start it the power light comes on but nothing happens?
    Sergeant:
  • 186 Answers
Try to re-seat the memory modules.
Posted on Mar 15, 2011
    Master:
  • 451 Answers
Try taking out the memory and reinsert it again.
I can't seem to locate a replacement battery that fits
Be very carefull of aftermarket batteries (cheap), get one from a reputable dealer. If you have a issue you can return it try here: http://www.amazon.com/Samsung-NP-N150-PLUS-Battery-4400mAh/dp/B006YZVOK0 Some cheap Replacement batteries at best will not work properly/long, at worst can be a fire hazzard. Never leave a laptop with battery inserted unattended.
Nov 20, 2012 | Samsung N150 (36725723009) Netbook
How do i remove or reset password for bios on samsung nootbook
Removing the CMOS battery like the one shown in the picture to the right will cause the system to loose all CMOS settings including the password. To do this locate and remove the CMOS battery on the motherboard for at least five-minutes. After this has been done put the battery back into the computer and turn it back on
If this does not help try these other methods
Oct 15, 2011 | Samsung N150 Plus 101inch netbook
Can i use ddr2 800 2GB on N150plus
Dear Urmsar,
Unfortunately you can't use DDR2 Ram on your laptop, There are 3 models available on samsung N150P Netbook series , three of them supporting DDR3 Ram only, It is the latest technology, by using DDR3 you can occupy 8GB Ran on a single slot... DDR2 supports maximum of 2GB per Ram..
Thank you
Sep 10, 2011 | Samsung N150 (36725723009) Netbook
Which is the correct DDR2 or DDR3 How many pin connections are required
Both DDR2 and DDR3 RAM modules have 240 pins, BUT the notch in the memory modules are slightly different positions in the DDR2 and DDR3.
The notch in the DDR2 is in the middle of the RAM module BUT the notch in the DDR3 is offset slightly off the middle of the RAM module.
Jul 03, 2011 | Computers & Internet
Samsung n150 plus is expandable to how many memory?
The Samsung N150 Laptop comes installed with 1GB of Memory and can be upgraded to a maximum of 2GB Memory. This computer has 1 (one) SO-DIMM memory slot, so to upgrade to 2GB of RAM, you will need to replace the installed RAM module with a single 2GB PC2-5300 DDR2-667 200pin SDRAM SO-DIMM memory module.
If you find this solution helpful, please leave a positive rating!
Jun 21, 2011 | Samsung N150 Notebook
Will my shuttle fd30 plus motherboard support a ddr3 gt 430 video card and a ddr3 memory card?
Yes it will support DDR3 GT 430 Graphics card.
But it will not support DDR3 RAM.It only supports DDR2 RAM.
Thanks for using FixYa.
May 26, 2011 | Computers & Internet
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
Removed 256 meg card, installed ddr2 1gig card. Computer would not start.
Old system!
Up to 2GB DDR are fine, but you tried DDR2, which it can't handle. Get the right kind of memory (just DDR, not DDR2 or DDR3) and see if they don't get along better.
Jan 03, 2011 | Dell Dimension™ B110 PC Desktop
"Memory Turbo Card must be installed with either DDR2 or DDR3"!
It is not DDR2 or DDR3, it is new memory technology developed by Intel which is a flash memory module which reduces the time it takes for a computer to power up, access programs, and write data to the hard drive.
May 03, 2010 | MSI X48C Platinum - Socket 775 for Intel -...
Black screen on Boot
1. Check the memory modules are correctly installed.
2. Check that all the installed ram is DDR3 - this board will not accept DDR2 andDDR3 together.
3. If you have more than one memory module remove one and try booting. If all is ok try just the other one.
4.Try with DDR2 memory
Oct 30, 2009 | Intel Motherboard
Samsung N150 (36725723009) Netbook Logo
169 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
