Question about Matrix T3Xi Treadmill
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
  • xavo1 Mar 16, 2011
    i payed for this question yesterday and havent got an answer back.
    sorry, i did got an answer, thanks
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Posted on May 01, 2011
    New Friend:
Hi, i have an Error signal "E3 " the treadmill stops and cant run anymore. thanks a lot
Posted on Aug 31, 2013
    Problem Solver:
  • 6 Answers
You may need a new controlled..you may have to update you software. check out this link
Matrix Treadmill, (T5x, T7x) Control Board, Motor, 1.5KW/90~264V, JHT01
Posted on Sep 29, 2012
I get an error message E1 on my Athlon model Simplicity treadmill. Belt stops. Any ideas on what this means?
Step 1:
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Clean the s.speed , test for open or faulty-see the diagram for adjust. tight the connector very well.
God bless you
Step 2:
Feb 08, 2013 | Exercise & Fitness
Err1 error message, york aspire treadmill
Clean the sensor, test for open or faulty, tight the connector very well,adjust it, see the diagram attached.
God bless you
Jan 19, 2013 | Exercise & Fitness
Treadmill stops dead with error 1 showing
Step 1:
Adjust the sensor speed see the diagram attaached, test for open or faulty. Clean it, and tight very well the connector
Step 2:
However you must LUBE the deck belt+rollers bearing see the video attached.
If the porblem persist, TIME to replace the old board deck belt
God bless you
Jan 10, 2013 | Exercise & Fitness
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    Dcmd67m digital signals to control the board
    Hi, on the DCMD67M the motor run for short time (less than 1 sec) and stop and the error led (red) turn on, P1 displayed on the screen. What is the problem. Thanks
    Feb 24, 2012 | Endurance T3 Treadmill
    About 10 second upon start-up, the Cybex 520T Treadmill would abruptly stop and display in the consul is an Err3. We transferred the speed sensor of the unit to another Cybex treadmill and initially the...
    Error 3 is an indication that the speed sensor signal has been lost. Check the speed sensor gapping on the machine you were initially having the issue on. If the speed sensor worked on another machine, I would think adjusting it when you reinstall the sensor, should fix your issue. A lot of times, gapping or a build up of lint, dirt or other debris can cause the speed sensor error to occur.
    Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
    Jul 29, 2011 | RTO Cybex 520T Remanufactured Treadmill
    I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
    hi,
    from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
    ok
    Dec 26, 2010 | Horizon Fitness Horizon Motor T51...
    Message in the display "err 2" and my kettler treadmill doesn't work
    Hi Rendra,
    Try this:
    Switch the treadmill off and then on again.
    Push the "minus" speed button and the "stop" button simultanuously.
    If all is well you will now have entered the maintenance mode.
    Next push the "plus" speed button and the "stop"button smultanuously.
    Now you you've reached the error mode.
    Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
    The push start to erase the message.
    Turn the power off and then on again to restart the treadmill.
    With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
    Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
    May 10, 2009 | Exercise & Fitness
    Matrix T3Xi Treadmill Logo
    1,072 people viewed this question
    Top Matrix Exercise & Fitness Experts
    David Payne
    David Payne
    Sportsmith LLC
    Sportsmith LLC
    greg kinsley
    Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
