Question about Maytag MDG2706A Gas Dryer
Belt mjakes a noise when starting - Maytag MDG2706A Gas Dryer
  • lmoser60 Mar 16, 2011
    i figured that but how do i replace the belt
    how do i replace belt
  • 4,323 Answers
Hi
The belt is either bad or worn out, also the idler pulley should be checked. Hope this helps...please elaborate for further assistance.
Daniel
Posted on Mar 15, 2011
  • Daniel Scott
    Daniel Scott Mar 16, 2011
    Please check this video:
Squeeky fan belt noise after driving a little
It sounds as if the belt is dry. Belts dry out after a certain amount of time and then start to make chirping noises. If the belt is not badly cracked, you can try using a belt lubricant spray. These sprays usually only last for a short period of time, though.
Mar 27, 2014 | 2003 Fiat Siena
Tip
Squeaking of belt noise
A use tip for all car owners. no specific model/make.
The Belt of the a/c to the solenoid pulley or the main belts can create a lot of squeaking noise.
Start the car to hear the noise now pour some water into the belt and the noise will subside off . You have the noise confirmed of a belt as sometimes it will trick you to think of water pump bearings, alternator bearings or even engine noises.
Stop the engine and check for play in the belt if so tighten the belt If not use some chalk power or candle wax to be rubbed into the belt that was making the noise - the a/c drive belt - or the main belts..
Now start and check . the nosie would be reduced or gone.
You can have the belts changed sooner or later.
on Aug 31, 2010 | Ford Fusion Cars & Trucks
Engie high pitch noises
The most common cause for the noise is a slipping belt.
Either the belt is worn and stretched, or glazed.
If the belt tensioner is keeping the belt tight, you may need to replace the belt.
Feb 08, 2013 | 2005 Toyota Tundra
Slipping noise on starting the dryer. Belt noise?
belt is probly starting to be worn. and slipping on the drum of dryer make be a weak belt ten.
Dec 03, 2009 | Maytag Dryers
Noise from belt when the engine is cold
worn belt or too loose/tight. possible problem with the belt tensioner. replace belt first and recheck under cold start condition
Oct 25, 2009 | 2006 Audi A6
My car wont start, fuel pump problem?
fast high pitched noise? never seen or heard of this, done 100's of belts, this noise is caused by a belt being adjusted to tight, belts just break. do you have fuel pressure, what engine do u have?
Sep 28, 2009 | 1997 Chrysler Sebring
Belt noise when first starting engine
Don't use a "belt dressing"...
There may be oil or other substance on the pulleys.
Remove belt and clean all pulleys .. inspect belt for contamination from those pulleys.
That should do it!
Sep 08, 2009 | 2006 Nissan Frontier
91 buick regal 3.8L is making a loud clank noise in belt area
It sound to me like you have a bad belt tentioner check to see if it's real easy to move by hand if so change it problem solved .Hope this helps you out!!!
Jun 03, 2009 | 1991 Buick Regal
Primera 1990 P10 makes loud noise from belt when starting
i recently experienced the same issue. it can be your tensioner pulley or your water pump see the belts are connected to the pulleys and sometimes get worn out and need to be replaced. especially on a older car see a mecanic
Jan 31, 2009 | Nissan Pulsar Cars & Trucks
Start up problem
If the belts are making noise, the alternator may NOT be spinning fast enough to produce sufficient voltage to charge ther battery, because the belts are slipping, and slipping = noises.
Tighten the belts.
Regarding the starter: Replace it, or get it overhauled at a starter repair service. You have bad starter contacts
Sep 30, 2008 | 2003 Toyota Corolla
Maytag MDG2706A Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
