Question about Kenmore 45081 Front Load Washer / Dryer
Hello, I have a Kenmore Front loader, model # 41743042200. It fills with water, but won't drain. When it comes to the spin cycle it just hums and makes a noise without going further.
  • pamelarowlan Apr 18, 2011
    Thanks, I think perhaps we had the same "service" guy. We got a good laugh out of that.
    Sergeant:
  • 170 Answers
If yours has a kink plate at bottom front of washer remove it 3 to 5 screws at very bottom of kick plate.Behind the kick plate you will see the drain pump with a cleanout on the front of pump remove that by turning counterclockwise you will get a fair amount of water so lay down a few towels drain slowly.remove cleanout it is most likely plugged. put all parts back test her out.hope I helped and good luck thanks for voting
Posted on Mar 15, 2011
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
  • Buzz Carroll Apr 16, 2011
    I had this very same problem with the same machine. Sears came out several times, changed a bunch of parts...and solved nothing. The last time they were here, when the guy had the kick panel off, I looked in and saw where the wiring harness connects the the plug in for it...a bunch of wires together. I asked if it was possible that might have separated from where it connects, and he glanced at it and said no. He then went ahead and ordered still another part...a circuit board this time. I still felt the strong vibration from the spin cycles could have loosened that plug, though. When he left, I pulled the kick plate back off, and reached in to see if I could push the wiring harness plug in any further...AND I COULD! I tried the machine, and it worked great then! I got one of those plastic zip tie things and wrapped it around the harness connector and the plug in point, and tightened it to keep them together. That was a few years ago, and I've never had that problem you described again. Oh...and I told Sears to cancel that damn circuit board and told them where that "service" guy could store it! Good luck...that problem drove us nuts before I did what I did.
    Thanks, this helped. I think we've had the same "service" guy you did. My husband broke out in laughter with your comment as to where the circuit board was going to be stored!
    Problem Solver:
  • 3 Answers
I had that same problem with the very same machine. I won't go into the several service calls Sears made, and the number of parts they replaced...none of which solved anything. The last time the repair guy was here, and had the kick panel off, I asked if it was possible the wiring harness down there might have vibrated loose. He glanced at it, then said no way...and he ordered a circuit board this time. When he left, I took that kick panel off and reached in to see if that harness was loose...AND IT WAS! I tried the machine, and it worked just like it was supposed to. I got one of those plastic zip tie things, and wrapped it around the wiring harness plug and the thing it plugs into...and tightened the zip tie so the plug couldn't separate again...and it never has...and the machine has worked just fine ever since. I told Sears to cancel that circuit board, and told them where that "service" guy could store it. I hope this works for you...it drove us crazy for weeks and weeks before i fixed it myself. Good luck!
Posted on Apr 16, 2011
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Will not drain or fill
just hit it with a hammer. thats what worked for my flat screen tv.
Sep 11, 2009 | Kenmore 43142 Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Kenmore 45081 Front Load Washer / Dryer Logo
359 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
