Question about Breville BBL550XL 5-Speed Blender
The blade has become VERY tight and will hardly turn. When I turn on the blender the motor strains to get it turning, and when it does it makes a horrible sound. I've stopped using it because I don't want to burn up the motor. Does the blade bearing, or whatever it is, need to be greased periodically? If so, how do I do that?
    New Friend:
Put a socket or a wrench on the nut in the middle of the blades, and hold the other set with a set of pliers, and, as the original poster said, it is reverse threaded.
Posted on Mar 20, 2015
5 Suggested Answers
SOURCE: Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Posted on Jul 25, 2008
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
  • 5 Answers
SOURCE: blades need to be greased, but I don't know what
To take the blades off, grab the blades with a rag so you don't cut yourself, then grab the other end with a rag and turn CLOCKWISE - it's reverse threaded, so lefty loosey doesn't work here, it's lefty tighty, so turn to the right. Figured it out after an hour of mental anguish
Posted on Jan 15, 2010
pappapumpdaf
  • 635 Answers
SOURCE: grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Posted on Mar 09, 2010
The blender blades are only moving really slowly. Can I open the blender to clean parts that may be sticking? If yes, then how do I do this?
If blender blades are realy turn to slow in most cases the armature of the motor can having a few bad collectors where the carbon brushes can be to short but have been warned of the risc to order new carbon brushes that they can be becomes as short as the old ones in a real very short time, so make a ohm measure of the armature collectors over the carbon brushes if there is a thermal closure in the anchor(armature), in most case you can smell the problem or hear it and sometimes feel it because the motor becomes hotter then normally that its no longer has the right speed anymore.
Replace the blender is most times marketing technical an better option then repair it. but its in priority depend most on the brand and price.
Feb 17, 2016 | Blenders
How to fix the blender,the motor works ok but the blades don't move
check to make sure the drive stud is spinning with the motor. If it is, make sure the blade assembly is lining up correctly as well as fitting tight on the drive stud. How to Repair Blender How to Repair Small Appliances Tips and Guidelines
Dec 09, 2014 | Oster Blenders
I have had my Cuisinart SmartPower blender for about 10 years now and it has worked great. Recently there has been a black dust/stain/residue that is on the underside of the bottom collar/blade and on the...
At 10 years you are heading to replace it. With the blender bowl removed, try turning the connector the goes to the blades. Then do the same with the connector on the base. Whichever one doesn't turn easily is the one that is failing. Usually there is corrosion in the spindle of the jug and this causes tightness which in turn causes the connectors to shred. The tightness cause friction, which makes the plastic parts get hot. The blade should spin easily, the connector on the motor, not quite so easy. On some blenders you can switch the base on with out the jug being on it. Run it for 30 seconds and then switch off. If it stop dead, then problem is with the base and the spindle that goes to the motor. In a catering environment, I had a Hamilton Beach, shatter the base connector after 2 years. With blenders, you get what you pay for, Cuisinart aren't bad, but there are better makes if you use them a lot.
Aug 19, 2017 | Cuisinart SPB-7 SmartPower Work Top...
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
How can I change the blade for my 2 speed hand mixer? The model type is NC-12 if you need to know
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver.
Things You'll Need
  • Flat-blade screwdriver
    • 1 Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
    • 2 Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
    • 3 Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
    • 4 Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
    • 5 Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Jun 07, 2011 | Blenders
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 | Blenders
Blades need to be greased, but I don't know what to use or how to do it. Motor seems to be working too hard, and blades do not turn. Devise turns when blender container is not on it.
Oct 11, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Motor works but blade not spinning
Check and make sure that the shaft in the base housing spins. If it does, the blade assembly has become disconnected from it's shaft probably due to an improper spot weld or peening of the blades to the shaft, or has torn loose or ripped the splines out due to an immovable object trying to be spun. A jammed ice cube can do this. Blade assemblies can be had usually directly through the manufacturer and usually on line. If this has helped, please rate it accordingly.
Jul 20, 2009 | Westinghouse 0101 IntelliBLEND¿ Work...
Krups blender blade stops
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Jul 03, 2009 | Blenders
Blender blade not turning, rotating piece on base not connected
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Breville BBL550XL 5-Speed Blender Logo
609 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
